61.0°W Amazonas 3
cokeaddict
Vu+ Ultimo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE v1 & v2, Solo2, Ultimo, Uno, Duo, Motorised CM 1.2m dish, Hybrid Titanium Smart Lnb with CM feedhorn and a Zone2 minidish with Inverto Unicable II
53°E - 45°W
Anyone know if these transponders are still active ?
nelson_b
Contributor
hi -
yes just had a look here -- still active
12642 H 28888 is showing a very strong signal
cheers --
cokeaddict
53°E - 45°W
nelson_b said:
hi -
cheers --
Is it dvb-s or s2 and do you have an fec by any chance ?
nelson_b
Contributor
hi--
they are DVB-S and fec is 3/4 according to lyngsat listing
cheers
cokeaddict
53°E - 45°W
Sadly I can't find this bird :(
Archived-1
Persona non grata
uk
a few things could stop you getting this bird :-), location>line of site>will your dish go that far ?.
cokeaddict
53°E - 45°W
I'm thinking my elevation is slightly out, as signal is weak at 45­°w, my dish will go well past 45w though.
cokeaddict
53°E - 45°W
martin-f said:
well I can get it on my 1mtr dish, but not on my 1.2 as I only have a 12 inch actuator on the 1.2 and can only hit 30w to about 55e,
if you really want to get that far round it would be a good idea to a post here http://www.satellites.co.uk/forums/385-dish-setup-single-sat-multi-sat-motorised-systems/
with more details/ maybe some pics of your setup :-).
With my old triax TD110 and Motec 2100 motor I used to get 57°e to 58°w without a problem (even picked up a few transponders from the old nilesat).
I removed that setup about 2 years ago, and replaced it with a Channel Master 1.2m with polar mount and 18" actuator.
Since then the furthest west i've found anything is 45°w as all signals have vanished from 58°w, but the furthest east I can go now is 53°e as the dish hits the pole lol.
30°w is 370 pulses on the v-box, 45°w is at 570 pulses and the west limit (before my dish hits the roof) is at 828, so I guess it's also possible that it doesn't quite reach round far enough to catch 61.5°w either.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Both transponders lockable on the TD88 ..
12.641H 6.1 db
and
12522 H 4.5 db
pity there is nothing to see ..all encrypted...but do-able on a relatively small dish
rgds
VS
Archived-1
Persona non grata
uk
Still not much happening here, things may change in the future and I will continue to look,
Terryl
Custom built PC
If your trying to look for 61.5W Echostar 16, try TP 12414L, use a symbol rate of 20000, with an FEC of 7/8, this TP has the "You have a dish at 61.5W" channel on it (channel 9582) and is in the open.
Costactc
Canada
Well, well...look who made it here from my side of the pond. Hope all is well with you my friend. Dish network sat all nagravision encrypted with the exception of the trailer as Terryl pointed out.
pontiend
Contibruter
south yorkshire
I have not looked at this satellite for some time.I set the TM blind scanning while I was doing something else.All it found was tv 1-15 on 12642 H 28888 73% scrambled.
TM 5402HD TD88.
Tururu
Assembled with recycled parts
Recycled as the owner.
Amazonas 2/3 at 61.0°W
Continuing active 2 tp's for Europe (Jun-2013).
This position we have located many since 2005 when tp 12563V27000 locate the data (LyngSat it would never add satellite), the tp disappears late 2011. Throughout Spain could tune antenna is 80cm.
Tp is a very good sign (reported OK with 60cm antenna), the other has lower levels for days and can not be active.
12522 H 28888 3/4.- SNR 62%, AGC 99% BER 0 10.0dB
12642 H 28888 3/4.- SNR 81%, AGC 99% BER 0 13.0dB ==> with perfect 60cm in Spain (peninsula).
Changes since summer 2013.
Being single horizon, ostaculo takes away any sign, in my case, a wall of 125cm leaves me almost blind to this position.
For a few days (+24/26-1 -2014), "TC My Channel" and "TV Series" issued in open / fta, now they are again coded tp 12642 H 28888 3/4.
Active channels now.
PS: Good fishing.
Amazonas 2/3 a 61'0°Oeste.
Continuan activos los 2 tp's para Europa (Jun-2013).
Esta posicion muchos la tenemos localizada desde 2005 cuando localice el tp 12563V27000
de datos (LyngSat nunca lo quiso añadir al satelite), el tp desaparece a finales 2011.
Por toda España se podia sintonizar con antena de 80cm.
Un tp tiene muy buena señal (reportan con 60cm de antena OK), el otro tiene niveles mas
bajos y durante dias puede no estar activo.
12642 H 28888 3/4.- SNR 81%, AGC 99% BER 0 13.0dB ==> con 60cm perfecto en España (peninsula).
Cambios desde el verano 2013.
Al estar a ras de horizonte, cualquier ostaculo nos quita señal, en mi caso, un muro de 125cm me deja casi ciego para esta posicion.
Durante unos dias (+24/26-1-2014), "TC Mi canal" y "Gama TV" emitieron en abierto/fta, ahora están de nuevo codificados, del tp 12642 H 28888 3/4.
PD: Buena pesca.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Seriously doubt we'd have any chance at all Terryl ..
The bird you refer too has no European Beams ...Just US tight Conus ..
Nonetheless ..welcome to the group mate..
rgds
VS
Costactc
Canada
Just scanned in this 9 channel tp with Filon being the only channel with programming:
Amazonas 2-61w
12174 V 30000
mpeg-4
Must be a North American footprint:
Tururu
Europe does not have emission normally, but these two tp's activated we can tune by mistake or some proof.
Years only lasted one month ago the error in the satellite Hispasat 30°West of the tp's to america for a month it could tp tune it in Europe but.
Some photos of the satellite spectrum where we can see tp's assets, the rest, there is nothing worth.
The marking is tp 12642 H 28888 with 75.6dbμV in spectrum analyzer (Rover SRM-50).
As you can see, there is more tp's assets.
Para Europa no tiene emision normalmente, pero activaron estos 2 tp's que podemos sintonizar por error o alguna prueba.
Hace años, en el satelite Hispasat 30ºOeste , de los tp's para america, durante un mes se podia sintonizar el mismo tp en Europa, pero solo duro un mes el error.
Dejo unas fotos de espectro del satelite donde podemos ver los tp's activos, del resto,no hay nada valido.
El tp marcado es 12642 H 28888 con 75.6dbµV en el analizador de espectro (Rover SRM-50).
Como se puede ver, no hay mas tp's activos.
Terryl
Custom built PC
Hey Costa, yah this side has some different hardware questions then on our side, I like to go back in the far reaches of my mind to dust off the stuff from the other side.
Terryl
Custom built PC
rgds
VS
Use a big enough dish and anything is possible, these satellites don't have good enough side skirts to keep it all in one spot.
I have a friend down in South America that works at a deep space monitoring site, he can get the American DVB satellites just fine with one of the 20 meter dishes, hooks his subbed Dish STB up when he is alone, watches American TV programming, keeps him from going all cabin fever type thingy.
