Astra 1N moving to 19.2E
Retired Mod
www.timo.me.uk
Out of curiosity, has anyone got a 28E 2C footprint map?
These are the two I had. I used to pick it up well on a 60cm in northern Finland.
Tururu
Assembled with recycled parts
Recycled as the owner.
astra 1n pass 25.5e
next satellite 23.5e meet next two days
These are screenshots of the beacon Astar1N 11453V 25.5°East, between 14:30 ~ 15:17 GMT.
They are the first, if you have any partner to compare, I would appreciate.
Lest this wrong.
Thank you.
Estas son las capturas de la baliza de Astar1N 11453V en 25.5ºEste, entre las 14:30~15:17GMT.
Son las primeras, si algun compañero tiene alguna para comparar, se lo agradeceria.
No sea que este en un error.
Gracias.
Tururu
Hello,
I was torn between 11452.75 or 11453...
I note another beacon 11443 H.... you can check the exact frequency?
Approximately/aproximadamente. (Rover SRM-50 1700€ meter).
Beacon 11440H 25.5º
M60
Northern England
Cheers Timo, interesting the 2C antenna modelling covers Madeira as well as the Canaries too.
Lest this wrong.
Thank you.
Gracias.
I have that as 11452.75V on my Promax by comparing the reading I get with the known 11701.75V beacon on the adjacent Astra3B 23.5E (which 1N is nearly moving to).
Beacon 11440H 25.5º
I make that beacon 11441H, but perhaps my Inverto's DRO is off true again.
Tururu
Signal levels beacons 25.5°East (18-2-2014 14:20 GMT).
11453V and 11440H day 02/18/2014
Included 11453V the day 17/02/2014, that leaves me.
From 2dBμV to 3dBμV less signal today, I have to move the antenna about 25ºEast to regain levels.
The analyzer has a function that analyzes the tp and center frequency, these does not work and is hand made in the center.
Niveles de señal de las balizas en 25.5ºEste (18-2-2014 14:20 GMT).
11453V y 11440H dia 18-2-2014
Incluida 11453V del dia 17-2-2014, que me deje.
De 2dBµV a 3dBµV menos de señal hoy, tengo que mover la antena sobre 25ºEste para recuperar niveles.
El analizador tiene una funcion que analiza el tp y centra la frecuencia, con estos no funciona y esta puesta a mano en el centro.
astra 1n now 24.6e
2c receiver 5 tp with 3.7m
satellite problem antella solar
Tururu
Thanks for the information Llew.
Photos anallizador spectrum to compare within a few days at 23.5 ° East.
I located the tp 11682V, 100% identified.
Located beacon 11700V.
Gracias por la informacion Llew.
Fotos del anallizador de espectro para comparar dentro de unos dias en 23.5ºEste.
Localizado el tp 11682V, identificado 100%.
Localizada la baliza 11700V.
astra 1n now 24.3e
same spectrum astra 2c 19.2e
Solly, what program are you using to create this graph?
i use sat spectr
better now sat ajust
astra 1n now 23.8 e
mid day wil be pass 23.5 e
mesolite
Drake 101
Among the human beings...
Hello!
What type of channels will we have on Astra 1n?
Thanks!
astra 1n same position like astra 3b
23.5e any becon on 23.5e ?
To start with probably most of those currently on Astra 2C.
it be nice 11914h will be back stronger signal like 1m europe beam
Tururu
Astra1N satellite photos with spectrum analyzer 23.5º East.
Located beacon 11453V .
Located beacon 11700H.
Located tp 11682V, 100% identified.
Fotos del satelite Astra1N con el analizador de espectro en 23.5ºEste.
Localizada la baliza 11453V.
Localizada la baliza 11700H.
Localizado tp 11682V, identificado 100%.
