Tururu
Assembled with recycled parts
- See signature
- North of Madrid (28703 Spain) -3Km of IKEA (40.545847, -3.612012).:-)
No es buena idea.Hi everyone, I'd be grateful of some advice from those of you with experience installing dishes. I am planning to buy a 110x120 Tecatel offset dish to receive Astra 2E in Madrid and I would like to know if the bracket in the picture below would be suitable/safe for fixing the dish to a TV mast similar to the one pictured below. The bracket is 850mm long, 40mm in diameter and is made from 2mm thick galvanized metal.
Thanks for any comments.
1.- La torreta es flexible y con algo de viento, todo se movera.
2.- El tubo del soporte es frexible para el peso del conjunto antena/LNB 12Kgs.
3.- Tengo esta instalacion para pruebas rapidas.
Normalmente las torretas que tenemos en casa son de 18cm/20cm o menos y estas son flexibles, siendo de las buenas, si es de las malas, no parara.
Not a good idea.
1 -. The turret is flexible and with a bit of wind, everything will move.
. 2 - The tube is frexible to support the weight of the antenna / LNB assembly 12Kgs.
. 3 - I have this installation for fast tests.
Usually the turrets we have at home are 18cm/20cm or less and these are flexible, being the good, the bad if not stopped.
