Archived-1
Persona non grata
- uk
Thank you rima, a grinder can soon make pigeon sh*t look good lol
It can't make it strong thoughThank you rima, a grinder can soon make pigeon sh*t look good lol
i know that, i used to work round welders and it was a saying to them passing the time of day and tormenting each other about there work,
I know very little about them Huevos tbh, when I used to weld mig was up and coming, it claims to be able to weld 5.4mm ?.Is that an inverter model? I've owned lots of real mig welders over the years and my bet is a little machine like that can't produce anything like enough heat to weld anything like 5mm. The welds would just sit on the top.
.The site I listed has a good calculator suggesting what setting to use on what thickness of steel. You input minimum and max current and number of power settings and it comes back with what thickness can be welded in each power setting.Thanks lads, ive put a post up on a welding forum, I think we are just guessing, things have changed lots since we was younger, thanks for your time and help.
Fond memories
We both walked away. I had a hole in back of leg where it had hit the under seat fire extinguisher and next day had whiplash. Moral to the story, expect the unexpected ;)
great fun in wet round roundabouts
