hi to all
And now a few words about this project:4,6m PFA installation-by @DX Bozoth
the project was started in September 2013 and he hope to finish it this year 2014
the dish mount can work between 140E-71W (made some changes in the mechanical mount)
he wants the dish to be operational between 100E-58W
also he want to receive this satellite ---express-A2@103E
the dish is not working yet fully 100%
now is running various tests, adjustments, calibrations
best regards from DX Bozoth
Like I said:He is at 47°19' N 21°07' E
Express A2 has 7.0° inclination, is over the horizon there for several hours, topping at 2.3° elevation.
No big deal!
How do you calculate or where can you find the maximum elevation of 2.3°?Since it is in inclined orbit, is the bird receivable when it reaches it's highest apogeum, when the bird is app. 120 km further from the earth than non-inclined satellites, so it peaks just above the horizon?
Indeed that's a great program, where do I find the latest TLE database?By using Gorbtrack. (There are many other more graphic softwares, but Gorbtrack suits my needs perfectly)
Enter the location coordinates, the latest TLE database, then adjust the time manually to find the highest elevation.
Best choice for TLE's to start with: http://www.celestrak.com/NORAD/elements/geo.txtIndeed that's a great program, where do I find the latest TLE database?
Also is there an update for the sats.csv?
message from: DX BozothHe should allow people to visit his place. I wouldn't mind paying even!
Planning officers and Esthetically Pleasing..
4 words not often found in the same sentence...
