Arandu Rape ..43West ..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
hi VS tried this channel this evening zero it seems it is a midday thing.
Will try again midday tomorrow ..
looks like your lnb is out 90 degrees ..lol
pride21
Sandown Isle of Wight
my mistake its the grey cells packing up
nelson_b
Contributor
hi -
just been having a play with the new PLL Cband l.n.b. that i finally received yesterday - the stronger transponders at 55 west showed no improvement over the BSC421 -
but here on 43 west on the Cholusat transponder on 3877 V 1546 - a good gain ,
with the BSC i can get a lock (just) at 3.5 db
the PLL is giving me 4.4 db
having fine tuned it to the max on this t.p - i,m leaving it on the dish now to check out other linear sats later today . i,m not expecting such gains on all weak sats but its an encouraging start:)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well done Nelson ..
First time you've locked anything here isn't it ?
nelson_b
Contributor
Well done Nelson ..
yes it is -- but the signal here on this t.p went from 4.0 db to 0.0 db in the last 30 mins --
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Yep ..it does that ...
very much TOD in the UK this bird ..
Still ...it's another feather for your cap.
pride21
nice one nelson I found midday was the strongest then it started to get weaker.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..And the Unicanal /Tigo Sports mux is stronger in the evening ...
Lockable last night here at 4.2db..
Sadly encrypted so nothing to see for me..
rgds
VS
pride21
nice one VS I will give it a go,have you tried CNN on 4040H I some times get up to 45% quality but no lock it probably needs at least 48% before some sort of lock I also have to nudge the dish to the east to get maximum gain.
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
3895V 17405SR all channels is unencrypted.
This is new to me :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The mini mux that used to be Rape/Unicanal at 4060 V ..then shut down in favour of Unicanal /Tigo sports at 4064V ..has expanded again and now has included Paraguay TV ,,
Sadly no pics as yet as it is even harder to lock than ever ..
Still 4444 SR ..and will add a picture if I ever get one as Paraguay is fta ..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ok .. sorry for the delay ..
Had to wait till this evening for a lock ..
this mux is always a fraction stronger in the evening till about midnight.
rgds
VS
