Astra 2C's move to 28.2E
astra 2c 20.8 e now
Pride Of Cucamonga
Valencia (city)
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Not misplaced. Most satellites located at 19.2, 23.5 and 28.2 are interchangeable as back up system and do have similar footprints.
Pride Of Cucamonga
Valencia (city)
Shouldn't the footprint shift 9 degrees east and slightly south (?) when moved from 19.2 to 28.2?
C0re
Ede
VU+ Solo SE
That's correct, but it doesn't shift parallelly but it somewhat heels over.
Pride Of Cucamonga
Valencia (city)
That's correct, but it doesn't shift parallel but it somewhat heals over.
Hence my question of whether the footprint image is for 2C at 19.2 or 28.2?
C0re
Ede
VU+ Solo SE
In that link it's the footprint at 19.2. But at 28.2 it won't be different a lot, the Canary spot will remain.
Retired Mod
www.timo.me.uk
So according to the fact sheet it could replace 2A?
Well, the lower half of 2A but oddly they moved most of 2A's transponders out of reach of 2C when 2E arrived.
I've attached some footprints of 2C at 28.2E from 2009.
The footprint does have to point 9degrees further over because the satellite moves 9 degrees. But it does happen when the satellite is at test location because the satellite is tested with the same geocentric orientation.
Retired Mod
www.timo.me.uk
Yep, you just need to see some of the current footprints at 31.5E to see how they can reorient the old beams to suit that position better.
maybe return same footprint like 2009
astra 2c 21.3e now
Pride Of Cucamonga
Valencia (city)
Doesn't it depend on the satellite? Here is a picture of 1N's footprint when it was at 28.2 and it's quite a bit off, as seen by mislocation of Canary spot and shape of Italy. http://robssatellitetv.com/wp-content/uploads/2014/02/astra-1n_pan_european_ku_band_beam2_L.jpg
Also, according to SES website http://www.ses.com/4628719/astra-2c , 2C has one pan European beam, not north / south. Maybe they are just showing the south beam?
Retired Mod
www.timo.me.uk
Doesn't it depend where they want to point to beams? Tilting the beam north/south/east/west.
I wouldn't take too much notice of the SES site, according to that 1N now has just one European beam (ex PE2)...
Pride Of Cucamonga
Valencia (city)
I don't think the Astra satellites are designed with steering options on the European beams. And why would they? Extra costs and more to go wrong for very little benefit.
Even so, the attitude of the entire craft can be trimmed.
Retired Mod
www.timo.me.uk
They are not steerable in the true sense, but look at the beams of the old birds at 31.5E to see how fixed footprints can be manipulated.
washoris
4.2 meter prime focus with invacom lnb
cyprus
astra 2c is at 21.8 right now.. anybody knows when it's expected to arrive??
No, but at a rate of around 0.6 deg/day, extrapolation suggests around 10 days.
But there appears to be no haste - we originally thought it would move more or less immediately after 1N assumed service at 19.2E.
And SES-Astra don't provide anything but the most rudimentary PR.
PS: Which Tracking Resource are you using?
washoris
cyprus
