- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
OK, have this motor laying on balcony already several days, but did not do much with it. First of all, motor is quiet old and has lots of oxidation and corrosion. Secondly, many screws, nuts and bolts are stuck in their places and when you start to unscrew them, they easily break. For example, one of three bolts fixing upper plate lost its head during transportation. I tried to unscrew another 2 and seems they are also going to beak. Same happened with one of four screws securing plastic cup above the motor, that simply stuck inside, so I drilled it out successfully.
So, I am making this tread, cuz I fill I will need lots of time to restore this beast and, perhaps also modernize it.
First, will take everything apart, change nuts&bolts to INOX, replace damaged and too rusted parts to new ones. Modernization will consist of strengthening tho body to prevent possible cracks, improving fixing mount to antenna. Maybe even adopting motor to work with USALS.
Everybody is welcome to give your ideas and advices.
