esto
- Kathrein uas 912
- CE
I'm in Switzerland with a 80cm pointed at 4.8E (Astra 4A), and getting the "Europe Ku" beam at moderate strength/quality (about 80-90% str and 50-60% quality). I have some trees in the way that affect my reception.
I have been trying to get the "Nordic BSS" beam, also on Astra 4A, but Switzerland is just outside the coverage area, making that beam either not possible, or in the "fringe reception" realm. SO I tried different combinations of dishes and LNB's, but I still wasn't able to get the Nordic Beam. In any case, I thought it was interesting to see the difference between dish size and LNB.
I had a bucket of different LNB's, and was kind of surprised to see no real difference between them. I used a hand held "SAT-LINK" receiver connected directly to the LNB. I didn't move the dish, and after changing LNB, I would adjust the depth and skew to find the highest signal readings. I tested 2 different channels, "Espresso" and "Channel 5".
With a 80cm Schwaiger SPI996 (38.5db max gain) focused on 4.8E:
LNB (Telestar "SkyQUad", Grundig "GLS40", MTI "AP8-XTS2E")
Espresso: Quality 49-50% , Strength 80-90%
Channel 5: Quality 56% , Strength 92%
LNB Telefunken Quad "55724"
Espresso: Quality 50-51%, Strength 91%
Channel 5: Quality 57% , Strength 93%
LNB Inverto Black Ultra Quad
Espresso: Quality 53%, Strength 94%
Channel 5: Quality 59% , Strength 95%
Based on this, the bulk of LNB's were the same, with the Telefunken having maybe 1-2% better performance in quality, and the Inverto Black Ultra a 2-3%. So in all, I would say the difference in LNB performance is very minimal. Of course all these LNB's are relatively new and modern, I guess if you were to change out a really old LNB that was sitting outside for 10 years, the improvement would be more dramatic.
Moving on to the dish, I changed out the 80cm dish (measuring actually 82x72, and stating 38.5db max gain in spec sheet) with a 1m Triax dish (measuring 101x95, and stating ~40db gain max). Used the same Telestar LNB and pointed at Espresso channel:
80cm Schwaiger (38.5db): Quality 50%
100cm Triax (40db): Quality 63%
Changing the dish was obviously a much bigger improvement over changing the LNB. Moving from a 80cm to 1m dish gave about a 13% increase in quality, while changing LNB's (even the famous Black Ultra) only gave a 2-3% increase at best. Of course these are just my findings, I'm sure "your mileage may vary" ;)
