Wanted- Dr Hd F15
Hi Moonbase, was wondering if you had any of the Dr HD F15 left? I have send you a pm with details.
NI Sat Man,
Yes, there is an F15 decoder available, one of the buyers dropped out. I have sent you a PM and an email.
No worries if you do not want it, I will not struggle to move it on.
Rgds
Nisatman
Octagon1008se,humax fox sat,sky hd box, comag receivers. 60cm sky dish, 90cm with 9e,13e,19e,28e plus 1.2m with c/ku band.
Co down n.ireland
Hi moon base, I would be happy to buy it. I shall check the pm and revert.
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
I have tested the F15 against most of the Vu Range Solo, Solo2, Ultimo, Uno, Duo never had a Duo2 and it beat all of them hands down on my own system that is, The only one to come close was the Solo2
Can you show us in picture one example of comparison ? One very weak signal receivable with F15 and let's say Solo2.
Humaxboy
humaxboy1
Octagon SF 4008
Slovenia
I know that this what I am going to write doesn't have direct connection to F15, but it could be a challenge :)
I've had a change to test Vu+Solo2 directly with DrHD F16 & CT 5000 (F16 Soft). Comparison were made on 26E yesterday night, same LNB and dish on this 3 trp. which are on the edge of reception at my place.
10930 V 27500 8PSK 3/4
10890 V 27500 8PSK 3/4
10770 V 27500 8PSK 3/4
10930 V
Vu Solo2 - 0 db, no Signal for lock
DrHD F16 - 8 db, no green signal for lock
CT 5000 - 8 db, no green signal for lock
10890 V (!)
Vu Solo2 - 8.8 db, no problem, Audio/Video present, no freezes
DrHD F16 - 8.7 db, green for Lock, scan done, BUT no video only occasional sound
CT 5000 - 8.7 db, green for Lock, scan done, BUT no video only rare occasional sound
10770 V
Vu Solo2 - 9.4 db, no problem, Audio/Video present, no freezes
DrHD F16 - 9.1 db, green for Lock, scan done, Audio/Video present, no freezes
CT 5000 - 9.1 db, green for Lock, scan done, Audio/Video present, very rare video Freezes
This test is showing that Solo2 has a very good tuner. And I would like to get in hand some other receiver who will beat him :D . Maybe F15 ?
Fact is also that Solo2 has very selective tuner because frequency, SR, FEC, polarisation, system (dvb-s,dvb-s2) and modulation (qpsk, 8psk) should be entered very precise to get a signal.
CT & F16 don't mind if there is a dvb-s oder dvb-s2 signal, right frequency, polarisation and SR has to entered and voila - the signal is there.
CT & F16 also showing signal strength independently of the fact that it is not enough for Lock. This feature is not present at Solo2, which is a a big cons for him.
In the case of 10930 V i can see that I have 8 db which is about 0,5 db under the signal lock.
Humaxboy
artsi--
Nokia mediamaster with motor
DM 800 Hd clone Sim3?
Helsinki
You can find 210p firmware of this box from drhd-club.ru/
