Vipersan
Emmett Browns Ghost
- IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
In order to complete the Hughes modified feed assembly ...I need a washer ...effectively..
A specific thickness with a 10mm hole and an outside diameter of 18.5mm..
Yes I could make one with a struggle out of copper ..
But a 1p piece is not far off what I need ..
So centre punched the coin and drilled a 3mm hole so as to mount on a long M3 bolt ..
This I can then mount in the stand drill and hopefully turn down using the drill and a file ..in a poor mans lathe assembly..
Have reduced the diameter by 0.3mm so far ..and have to let the drill motor cool down for a while..
So thought I'd share a photo with you ..
I do hope HRH is a forgiving sort ..and doesn't throw me in the Tower for a 'penneth o copper' ..
After all I'm defacing her coinage in a good cause.
lol
lol
