loss of free to air hd
manutd10
dreambox dm800 fixed dish
manchester
any suggestions on how to recover free to air hd channels theyv gone greyd out
Are you sure Free To Air are blocked? By definition Free To Air are always clear and not reliant upon a specific box and/or Card.
Assuming you might mean stuff like ITV2/3/4 HD which are not Free To Air, currently not possible. Almost universally now only available to bona fide BSkyB Subscribers using a Card in a paired Box.
manutd10
manchester
oh ok thank
oh i see thanks for that my channel 5 5* 5usa an film4 seemed to have gone now im havin a torrid experience upto now im on all kinds of forums but dont get much help thanks for reply.
If you're using a "Gift" or other Commercial Card Share, no reputable Forum will help as such things are not only legally and morally dubious, but often unreliable.
BSkyB have taken steps to protect their Revenue by making Card Sharing access to HD Channels impossible and there have been several Prosecutions of Card-Share Providers.
Our advice on this Forum is to advise the acquisition of a Subscription from the Platform Provider.
manutd10
manchester
i have a list of free to air frequencys can i pt them in individualy scan an save the channel? if so how do i save the channel? thanks
I'll leave that one for a Dreambox owner to answer >> There are quite a few around on this Forum, so you shouldn't have long to wait.
"Greyed out" refers to the channel menu (a bit like what happens on a Humax Freesat when doing too many recordings). Happens on a Dreambox when satellites.xml doesn't correspond with lamedb.
Ok, thanks: Can you help our friend resolve the issue?
Probably but he started 2 threads about the same issue and I already replied in the other one.
Not seen that - Too busy cooking and eating dinner! Ok, thanks.
oh ok thank
Those are free to air channels - you may just need to tweak the alignment of the dish a little.
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Not sure what the problem is, but doing a re-scan of all the channels with the "network" option should retore all channels.
Also, when you say "greyed out" - where exactly? Infavourites or actually in the satellite "services"?
