Not much difference with SMW feedhorn. Sky News still came booming in.Will try SMW feed-horn in the coming days (F/D 0.5 compared to F/D 0.6 for standard LNBs), but clearly dish is not big enough for Eastern Denmark.
Sorry to hear you've lost the UK PSB channels.Belated UK SB reception report for SW Fyn, Denmark. Conclusion: Failed!
Astra 2 @ 28E UK SB 2E/F normally only available for a limited time period around lunchtime.
Varies, but usually solid reception between 11am and 14.00pm.
Only occasionally useful reception outside these times.
I have fine tuned my 1.8 Salora PF and lately a Kathrein 2.2m alloy PF dish to the last squeak.
My Fortec Star Passion HD receiver won't lock below 53% Q. Signal strength varies on UKSB between 72 and 76%.
The IRTE alloy feedhorn proved to be superior by 2% on Quality.
So the C120 conversion, which I turned to match the original Kathrein feedhorn, was a waste of time and material.
An Invacom feedhorn is unlikely to offer much extra over the IRTE despite a slightly better, theoretical F/D match.
I replaced the old coax cable with 33m of Webro HD100 with no change.
Now giving up on UK SB Satellite TV. The next step up in dish size would be complete madness!
I doubt a new receiver would help much either having tried a borrowed Kathrein with very similar results.
I haven't decided whether to sell all my dishes yet. If I moved to another location they might still be useful.
The presumption must be that I am sitting close to the null line which runs through Fyn in central Denmark.
Here's a link to an even longer, illustrated description of all my wasted efforts:
A TV Satellite Dish Restoration Project
RIP 2D. Alas, we knew Him well.
Yes, it did strike me as odd at the time too.@st1, that's a bit odd... my friend in Odense is getting pretty much everything that's not on UK beams on this "Squish" dish, which is surely worse than a 40cm Gibby?
Now the (admittedly fantastic) summer has come to and end, it is clear that the CM120 here does not provide ful rain-margin.Yes, it's clear-skies, low-humidity, good-weather conditions, but nevertheless, it works well.
However, this is a Channel Master 120 SMC dish (not some cost-efficient metal-pressing), and a good meter. So your end-milage will vary if you try something else.
2d was co-located with 2e/f, so there is only one optimal direction to point at. Get hold of a meter, then optimize azimuth and elevation first, lastly skew of the LNB. Skew is very important for quality at the fringes when the signal ffluctuates on daily basis. Also readings on boxes are often over simplified, esp sky-branded oned. Meters are much preciser, and allow you to specify exactly what frequency you are measuring.Newbie here.
Where in Bergen are you 4wd? I'm also in Bergen and am not having anywhere near as much success as you on 2E with a 90cm. Very poor signal first thing in the morning, gets better later on in the day and then starts falling out around 16:00. Admittedly it's still pointing at 2D but I'm assuming that it wouldn't make much difference (although I'm probably wrong about that!).
Any advice on size/setup would be great appreciated!
