ATV HongKong - Eutelsat 70B @ 70.5° East.
adonis1
ATV HongKong (FTA)
11294 H 44900 3/4
DVB-S2/8PSK
Widebeam ?
Will give this a go tomorrow, not sure if my dish is high enough to look that far east (just about gets 68.5e)..
Not a peep... But it is quite low in the sky for me, less than 2 degrees above horizon so not sure if there are things in the way.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Got 2 channels from this Freq although the Mod is QPSK and FEC is 2/3. Thinneta and & Filmi Bangala HD (but no video.)
I think this is wide Beam. Snr 54% with 1.2Dish
Kveys
Southern Finland
ATV World also on (76.5E) 3769H 13333 with almost same channels than 70.5E (KU). Not any sign from Ku here. C-band freq. very strong though.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
No video I meant as regards Filmi Bangala HD.
70.5 East-11293 H,44890,3/4,DVB-S2-8 channels are FTA now and one-BabyFirst TV-encrypted.Pretty strong signal in my area-10.9dB .
adonis1
Some more info :
New satellite operator Horizon Teleports headquartered in Munich (50 km from the city), has launched commercial services and have the first package transmitted by Horizon Teleports and satellite Eutelsat 70B (70.5 ° E) freq. 11293 H 44890 3/4 DVB-S2.
Teleports Horizon is equipped with 16 antennas (between 9.4 m and 2.4 m) and can provide services related to the uplink channel s (earth-satellite), turn around services and numerous other services, such as IP Trunking, GSM Backhaul, i-Direct VNO. Launched in May 2014 teleport is part of HorizonSat of Dubai .
Horizon Teleports have access to any satellite position in the range 78 ° E to 55 ° W , Ku-band, C and Ka, the current antennas are set for action on the satellites:
Eutelsat : 21B (21.5 ° E) , Eutelsat 70B (70.5 ° E) , Express AM 22 / Sesat 2 (53 ° E) , Eutelsat 7A (7 ° E) , Eutelsat 10A (10 ° E) , Eutelsat 3D (3.1 ° E) , Eutelsat 48A (48 ° E) , Eutelsat 36B (36 ° E) , Intelsat 12 (45 ° E) , Intelsat 10-02 (1 ° W) , Apstar 7 (76.5 ° E) , Yahsat 1A (52.5 ° E) and Arabsat 5C (20 ° E) .
Hi adonis1,
It seems to me that the packet from 11294 H(70.5E) has left the satellite.I checked today and you see on spectr there is no signal.Please check yourself.Thanks
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Hi adonis1,
Yes there is no signal at all.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Back on with 30 channels - 25 are test channels though. Snr 8.5db with Dr. HD. F15. Dish 1.2
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Another two Freqs found. One apparently from the African Beam on Freq 11520 V 3332 1/2 (Family-TV) DVB-S2 QPSK
and another from a feed 11206 H 3800 3/4.
adonis1
I have no rereption of Africa beam.
I think Horizontal polarity is on Wide beam and Vertical is on Africa spot.So,MTA Int is on Wide spot, and the Family TV is on Africa beam!That is the reason why I get the MTA International,especially as I have almost 8 dB on this transponder,and not trace of the signal on Family TV!
On the other hand,Test Package from 11295 is on horizontal polarity and not vertically as it appears on FlySat.Strangely,two tv packages transmitted on the same polarity on 11295?What do you think?
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Signal is weak 5.82db. According to flysat it's on the African Beam...But the symbol rate should be 3/4, not 1/2 as I wrote it (from Flysat itself).
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
On the other hand,Test Package from 11295 is on horizontal polarity and not vertically as it appears on FlySat.What do you think?
Yes I also am of the same opinion. MTA is much stronger 9.2db down here, although the African Beam doesn't extend to down here but somehow when I did a blind scan it came through and it's still here.
All blindscans that Ive done on 11208 H gave the same fec 1/2
Tried again today but still nothing. Haven't seen anything from this satellite since Canada's package left.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
That's Ok, but this particular African Freq should have a symbol rate of 3/4 and not 1/2 as inadvertently written by flysat.
