- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
I turned into a Grumpy Old Man years ago
Don't forget the problem these receivers have with dvb-s2 8psk channels with symbol rate <10000. For example try channels of eutelsat 3B.
It's even simpler: go to the channel with biss, press 8280 and here comes the biss menu.One advantage of this one is the BISS key is incredibly easy to enter once the receiver has been phantom patched. No faffing around with usb sticks to load a new file, just go to the cas menu and enter the hex code direct.
One advantage of this one is the BISS key is incredibly easy to enter once the receiver has been phantom patched. No faffing around with usb sticks to load a new file, just go to the cas menu and enter the hex code direct. I got a couple of the eastern European channels on the minor satellites opened in a matter of seconds.
And look below 27.5W already has the Beeb freq installed anyway (no signal as thats a blocked part of the arc here so theres no dish pointing round there!)View attachment 68946
Very useful for watching the Georgia Gibraltar game the other night ;)TUT TUT AS
Always thought you were a freebie satellite channel person with your setup scanning the heavens above
Did not in my wildest dreams think you would resort to loading BISS keys to open new ( scrambled/encoded ) opportunities
Regards
