Retired human
- See signature
- North Somerset
It should be active.. in theory!
Agreed CJ...It should be active.. in theory!
Good going buddy ..TBS6983 has found a transponder with low symbol rate on the Astra 2F-28.2E:11173 H,341,3/4,QPSK.The first of its kind on this satellite.What's great is that the card has found it on almost non-existent signal on the Analyzer.It is, if you will, a confirmation of the extraordinary sensitivity of the tuner,which I mentioned elsewhere.
Thanks for clarifying..You're right, I was supposed to say that I used Crazyscan with TBS6925 card just to prove that TBS6983 knows how to find transponders even when the signal is very weak.Of course that it is not possible to use Crazyscan with TBS6983 card.
Good findTBS6983 has found a transponder with low symbol rate on the Astra 2F-28.2E:11173 H,341,3/4,QPSK.The first of its kind on this satellite.What's great is that the card has found it on almost non-existent signal on the Analyzer.It is, if you will, a confirmation of the extraordinary sensitivity of the tuner,which I mentioned elsewhere.
Vipersan said:...when Frank does join ..please make him welcome.
