Astra 1N at 19.2E
Sky has optimized its transponder occupancy on the Astra satellite system at 19.2 degrees East. This affects the option channels, which are primarily used for sporting events.
The previously transmitted on transponder 73 of the Astra satellite system option channels Euro Sport 360 HD 6 Sky Bundesliga HD 7 and Sky Sports HD 8 switched to transponder 23 with the frequency 11553 MHz horizontal (DVB-S2, SR 22000, FEC 3/4, 8PSK ). Furthermore, have been posted on transponder 47 with the frequency 11171 MHz horizontal (DVB-S2, SR 22000, FEC 3/4, 8PSK) Sets the channel € 360 Sport HD 7, Sky Bundesliga HD 8 and HD 9 Sky Sport. Both were previously found on transponder 73.
19.2 E: MTV Base, Puls Idol and ended in SD
MTV Networks continues to decline distribution programs in classical SD resolution. After the recent disconnection of local SD version of MTV in Germany, held a similar step on the French market.
Programs MTV Base, MTV Pulse and MTV Idol SD cease distribution of the major European satellite Astra position at 19.2 ° E . These three MTV programs are now distributed in the same position in HD quality.
The TV operators QVC launched its third channel in high definition quality on the satellite platform Astra 19.2 degrees East. QVC Beauty & Style HD will go on air at the beginning of November.
The teleshopping provider QVC is expanding its HD broadcasting via Astra 19.2 degrees East. As the Broadcast Service Provider SES Platform Services announced on Tuesday, so that the third channel of the organizer QVC Beauty & Style will be broadcast in high resolution satellite after QVC and QVC Plus in the future. The starting gun for HD distribution will start on November 1st.
Relating to this topic
Go teleshopper under the digital diversity?
Change of leadership at QVC Germany
Week in Review: Quali-DFB future with RTL - Sport America HD
To be transmitted on transponder 33 read The reception parameters 10 964 MHz horizontal (DVB-S2 symbol rate SR 22000, FEC 2/3 error correction, 8PSK) . On the same transponder are among other things the transmitter TLC HD and MTV HD, the encrypted can be received via the HD-Plus platform. QVC Beauty & Style HD to be broadcast unencrypted, however. The new channel will be loud Christoph Mühleib, Vice President Sales at SES Platform Services, already the tenth German shopping channel, of his program in high resolution on the Astra platform to 19.2 degrees East radiates. provides an overview of the satellite frequencies of the most important for Germany satellites receive the daily updated DF-frequency list , the parallel as app for iOS and Android is available.
After the German pay-TV operator Sky in mid-September, a trailer preliminary evidence has given a new station called Sky Star Wars HD, the Group now has the cards on the table and tell you what it's all about Sky starts in early December - as the name was already suspect - actually an event channel, the program revolves exclusively around the famous sci-fi epic from George Lucas, as Sky announced on Friday.
Canal + / Canalsat: Towards the end of the only cards?
According to "Planet CSAT" CANAL + Group has decided to put an end to only cards for subscriptions Canal + and Canalsat.
Direct consequence for subscribers: the requirement to go through the rental of the Cube, the owner of Canal + decoder to continue receiving bouquets The Canal + Channels Canalsat and unable to subscribe to Canal + and / or Canalsat for owners TNTSAT a decoder.
Stopping only cards would be scheduled for summer 2015, ie the same time as the transition to all MPEG-4 operator announced in May.
It is looking for savings that would be the main reason cited by the Canal + Group reason for the abandonment of the only cards, including the costs of regular replacement of these cards, but also a matter of consistency of its fleet of decoders .
Information that has been confirmed by an internal Planet CSAT source of CANAL + Group.
the tp 103 12460h it transmited ?
I not get signal from this morning
also flysat post 11656v start service sps
also no signal yet
Retired Mod
www.timo.me.uk
also no signal yet
12460H is still on air with encrypted French channels.
11656V is on air with 25 services labelled "Service 10300" to "Service 10324" encrypted in Nagravision. SR 22.0, FEC 2/3, DVB-S2 8PSK
please write 12460h parameter if signal
bicose I see signal on spectrom no lock signal
Yup its still 12460H 27500 3/4 DVB-S
Sophia TV replaced iM1 on Astra Hits
11.11.2014, 15:35 clock, ps
The religious TV channels Sophia has been almost three months empty channel identifier of iM1 hits on Astra 19.2 degrees East over. The former music channel iM1 is thus finally disappeared from the scene.
After the music channel iM1 Hits since mid-August began broadcasting via Astra 19.2 degrees East, on the cable networks and Entertain has set actually, now the station name via satellite was switched off. Tuesday the still remaining placeholder on the frequency was 10 773 MHz horizontally (DVB-S2 symbol rate SR 22000, FEC 3/4 error correction, 8PSK) replaced by the channel TV Sophia, the newly was launched.
Comments about this topic
iM1 apparently turned off via Entertain
off iM1 Hits at Unity Media, Kabel BW
Again, time confusion about iM1
The religious transmitter is twice broadcast via the Astra position. Sophia least TV broadcasts on the frequency 11,421 MHz horizontally (DVB-S, symbol rate SR 22 000, error correction FEC 5/6). The most obvious difference between the old and the new offshoot is the change from DVB-S to DVB-S2 successor standard. This is decodable only with HD-capable receivers.
Free TV channels Anixe includes UHD cooperation with Plus X Award - broadcasting as ultra-HD version on Anixe
The free TV channels Anixe gave on 20 November on a collaboration for forcing the issue Ultra-High-Definition Innovation Prize Plus X Award known.
Charisma as Ultra-HD version on Anixe
The Plus X Award Night 2014, the award ceremony for the world's biggest innovation prize for technology, sports and lifestyle from June this year, will be broadcast soon as Ultra-HD version on Anixe. The Plus X Award produce the documentation to his award ceremony for six years future proof in 4K. Four years ago was even aired with the Plus X Award Night 2010 the world's first full-length TV show than awards ceremony in 3D on Anixe.
Donat Brandt, President of the Plus X Award, is pleased with the expanded cooperation with the Technology Pioneer Anixe: "The Plus X Award what he refers to as a symbol of innovation and technological progress. We want to take the chance with this strategic alliance, greater focus on the subject UHD in the German market in the foreground and act as a trailblazer for Trade and Industry. The immediate availability of 4K content in German Free-TV is a strong argument for the trade and it is an important signal for the end user that the UHD TV on Wi-receiver path is already possible today. "Says Brandt.
The Plus X Award honors products and technologies for their innovative edge. Until 15 January 2015, all manufacturers have the opportunity to attend the Early jury of the Innovation Award.
The start date for Sat.1 HD Gold is known. Already on January 1, the new HD program go on the air - for now however only via satellite.
Already early November ProSiebenSat.1 announced plans to launch an HD offshoot of his Sat.1 gold. Stand firm, then the date for the launch. Already 1 January 2015 will go over the satellite platform HD Plus on Astra 19.2 degrees East to the start Sat.1 Gold HD.
ProSiebenSat.1 switched HD channels at Christmas free
Cardinal Woelki is sat.1 Marriage Show "tasteless"
Sat.1 brings new presenter from Holland
The high-resolution transmitter is intended to be the first satellite viewers reserved. The reception parameters're right by this. Switches the program will be on the frequency 11 111 MHz horizontal (DVB-S2, symbol rate SR 22000, FEC error correction 2/3, 8PSK) . An overview of the satellite frequencies of the most important for Germany Satellite refer to the daily updated DF frequency list , the parallel as app for iOS and Android is available.
11229 VDVB-S2/8PSKMPEG-2 22000 5/6
new ses test transponder
please scan this tp
hd plus testing 4k
11421h sr-22000 fec 2/3
sid 4722PCR-PID 5375
The operator of the French satellite pay-TV CanalSat makes several changes in the distribution of programs. Optimisation is also free to broadcast French radio stations that are now found at the new parameters.
For the reception of French FTA radios must perform a new search by entering the current parameters. At the old rate, runs French radio broadcast continues, but already without their standard identification.
technical specification:
• Astra 1N ( 19.2 ° E ) freq. 12,363 GHz, pol. V, SR 27500, FEC 3/4, DVB-S / QPSK
disseminated radio programs
- RF
- Radio Courtoisie
- BBC World Service
- BBC Arabic
- Beur FM
- Radio Alfa
- Radio Notre Dame
- Fun radio
- Skyrock
- RTL2
- Virgin Radio
- Cherie FM
- RFM
- NRJ
- Nostalgia
- Contact FM
- Radio FG DJ
- Nova
- Jazz radio
- Oui FM
- TSF Jazz
- BFM Business
- MC Doualiya
- Sud Radio
- Rire & Chansons
- RMC Info
- Europe 1
- RTL
- Radio Classique
- RFI International
- France Bleu
- France Culture
- France Inter
- France Info
- FIP
- France Musique
- Mouv
DW English start 27 May
• Astra 1M (19.2 ° E) freq. 11,627 GHz, pol. V, SR 22000, FEC 5/6, DVB-S / QPSK, FTA
Pearl.tv Ultra HD from September on Astra
05/20/2015 09: 16.00 TODAY! | Print | Comments
logo On the European Astra satellite system at 19.2 ° E in the ninth month of 2015 started regular broadcasting of the first program in Ultra High Definition - Pearl.tv Ultra HD . Satellite operator SES (Astra) today announced the launch of the first program in uncoded Ultra HD in Europe, the main European Astra position at 19.2 ° E. German teleshopping channel pearl.tv will produce and broadcast their content in native Ultra HD resolution of September 2015. The parent company pearl.tv, Enstyle GmbH rents additional capacity to launch a new station into an agreement with SES Platform Services, a subsidiary of SES for provision of technical operations for Ultra HD broadcasts. Pearl.tv will continue to be available even in the classic SD and high definition ( HDTV ). " Years ago pearl.tv was the first shopping channel, which began broadcasting its program in native HD resolution. At the present time will start first in pearl.tv Ultra HD and once again demonstrate our strength as a technology leader in the European media industry. We also produce and broadcast pearl.tv in native Ultra HD from a brand new studio , "said Dr Michael Sichler, CEO Enstyle GmbH. " SES is a leading developer of Ultra HD since 2011. Our satellites can transmit a truly immersive experience Ultra HD, because the satellites are able to propagate native Ultra HD in extremely high quality throughout Europe to millions of TV households , "said Ferdinand Kayser, Chief Commercial Officer of SES. " We are proud to be working with our partner to achieve another milestone in the Ultra HD and broadcast the first commercial uncoded Ultra HD channel in Europe to 18 million meters DTH households in Germany . "
