Astra 2G Launch: December 2014
Not even trying to lock here :(
I am only 59% quality with my 104cm dish with the Astra 4A feed you should be ok on the 19.2 east feed when it goes live,
Still looking for the HD feed checked out 28.5E 23.5E 19.2 E 7E 4.8 E no sign of it so far.
Do they ever provide the feeds in HD?
Think my question has already been awnsered, as in yes if you can find it :D
I thought they did last time the SD feed on 19.2 east may change to HD.
The 19.2e one should change to HD when they change it from the SES logo if I remember from last launch.
Last nights Russian launch had Baikonur_1 and Baikonur_2 under the 12712H freq on 4.8E. Im wondering if the Baikonur_1 is the HD feed which may appear later.
It's FTA now, but with no so good quality picture.
1 hour & 10 min before they start the HD transmission.
hoi,
also on 7 east
IN Baikonur and Europe, THE LAUNCH BROADCAST WILL BE SEEN ON THE FOLLOWING (HD) (conf. 14/005851/01)
EBU REF 14/079002/03
EUTELSAT 7B 7 deg East TXP B1 CHANNEL 12MHZ SLOT 1E12
UPLINK FREQ.: 14285.5 MHZ POL Y BY FFTM DEARD UP1
DOWNLINK FR.: 10985.5 MHZ POL X
HD 1080i 50Hz DVB-S2 8PSK 9.875 Ms/s FEC 3/4,
Pilot: on Roll-off 0.20 (MPEG4/H.264 4:2:0 21.503 Mbps)
AUDIO:1 SOUND MONO
AUDIO:2 SOUND MONO
4.8 east has zoomed into the base of the launch vehicle in B&W now zoomed back out again in colour still SD no 2nd feed on this transponder atm
HD on 19.2 east now
The cradle arms have moved away showing the rocket ready to launch DSCN0632.webp
Some cracking tunes have replaced the Eurovision testcard.
The lack of HD feed on 4.8e makes me wonder if 19.2 feed will just have HD hosts talking and the SD feed we're seeing on 4.8 :(
4.8e feed is now horrifically bad signal.
