samoloko
- Aug 12, 2010
- Age
- 39
- 1.8 PFA
- EU
does anyone measured angle which Is between red lines on a Skyware feedhorn on channel master 1.2 / 1.8 / 2.4Some time ago i was surching for the best lnb position at a Triax TDS 64 , made a tool to messure the openings angle of a BU .
I dont know its the correct way to messure it but it came out to 55º , also in other brands lnb's . (red lines)
But since there are rumors that the receiving point in the lnb is in the center of a ball shaped aerea of ± 25 mm (according to the KU wave lenght) I draw the bleu lines .
