dielectric plate
Archive-8
Hi what material can I use to make a dielectric plate to turn a circular lnb in to pseudo liner?
Eg foil or old credit card ect?
Terryl
Custom built PC
Some have had success with a Teflon cutting board cut to size, but most just buy one for a "C" band LNB.
But some circular LNB's can't be changed over to a linear LNB, this due to the way the internal circular antennas are setup.
Archive-8
I have a couple of plates for c-band lnb's. I didn't really want to cut them up.
To try modding one of my Ka Band lnb's.
Costactc
Canada
Most, if not all, c band lnbfs come with the dielectrical plate.
BlindFaith
TBS 5925
..isn't that the other way round? ;)
BlindFaith
TBS 5925
if you want to use a circular lnb to receive linear polarisation, you have to remove the dielectric plate ;)
I know circular Ku LNBs have a plate in them like a C band LNB does. SL3 Ka LNBs use a different method... Using a 'septum' on the PCB itself. I don't know what's inside the Inverto one. Have you opened it up?
Archive-8
Not yet I was trying to find out a bit more first. I am going to have to remove the bed cap first.
Trust
Nijmegen Netherlands
Here the job I made at the Triax TKT 001 , the Inverto will be almost the same .
To have better control while milling the rests of the cutted plate in the throat , I put a PVC plate in the housing .
Or use a second dielectric in reverse ;)
Surely using a circular lnb to receive linear polarisation will simply result in a 3dB signal reduction. Or am I missing something?
Dunno. I was just talking theoretically about circular and linear polarisation.
BlindFaith
TBS 5925
yes, cross polarisation ;)
Circular polarisation wth a linear lnc will result in -3dB (both on the horizontal and vertical probe)
You would have to have H and V polarised signals on the same frequency for that though. H and V alternate to increase the differentiation between adjacent frequencies, or so I thought.
