31.5W (Intelsat 25)
pride21
Sandown Isle of Wight
that's strange I have adjusted 12283V its now coming in at 45% quality but zero on the other two
aceb
Prof Tuner 7301 /
Sussex
No sign of either ORTM at the moment but first time for Cherifla for me.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Those two channels are still here (ORTM Mali & TM2) plus Cherifla TV. Signal rather low.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Just want to clarify that I used the 1.5 Dish. With a 1.2 I only got Cherifla.
Ortm definitely weaker than it used to be but still coming in on the 1.5m
Archived-1
Persona non grata
uk
This satellite is a strange one for me, its not only the conditions has to be right, its also the time of day 5/6 PM then around 10/11 PM, I have read about certain satellites that do move backwards and forwards in a drift ?.
I am surprised to be getting it at all considering the official footprint is nowhere near Europe...
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Agree with you martin there...I had another go just now at this Sat only this time with my 1.2 Dish (2 of them with different receivers) and both channels are coming in
nicely. Today we have a N/W wind, although quite strong (5/6)and cloudy. Yesterday wind was S/W and semi cloudy. Another thing is that Cherifla registers a lower signal than TM 2 but is more stable. Probably in the evening I will have to use the 1.5 Dish to be able to receive ORTM
aceb
Prof Tuner 7301 /
Sussex
I can't get either of the ORTMs here, I guess the footprint drops off as you head east but the main problem is a strong data transponder on 30W 12344V 27500 @ 18dB SNR that probably blocks the weaker signal just 1.5° off beam. Before it was on air both the Mali signals were available and quite stable.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
No sign of Ortm or Ortm2 but I do get:
Gibertini OP125L
Basically same.....1.2m dish CheriflaTV ok (noticed that this time the word TEST appears above the time.
Couple of clicks to the west bought in ORTM2 (12344 V 2121) but no lock at 3.6db.....sure the FEC of 7/8 does not help us!
With those clicks to the west you can see that the two transponders from Hylas 1 came in to lock as well.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
At last managed to get all three on one scan-locked.....1.2m TM5402 mk3. :)
12284 V 2200 Cherifla TV
12340 V 2120
12344 V 2121
SatSearcher
West Yorkshire
Thought i'd have a go at these, and was very surprised to get a lock on Cherifla TV, coming in at around 5.0dB on my 1m dish, didn't think there'd be a chance on anything less than a 1.2m, but goes to show you don't know till you try! No luck with the 2 ORTM channels but think a lot of that is down to being drowned out by the huge data signal next door on Hispasat.CHERIFLA TV_3285 12284_V_2200_20150306_171843.jpg
Must be something unusual happen during this period, but for some time Atlantic signal beam increased surprisingly so much that can be received in my area also with of 1.10 m antenna.Worth to try.
Tururu
Assembled with recycled parts
Recycled as the owner.
Photos satellite channels/Fotos de los canales del satelite.
Better signal at 4:00/Mejor señal a las 4:00
12482 V 15000 DVB-S2
No interference Hispasat (V / H), 1'5º is much, as we see in the signal spectrum analyzer.
Sin interferencias del Hispasat (V/H), 1'5º es mucho, como vemos en la señal del analizador de espectro.
PD:Good fishing/Buena pesca.
Tururu
He stayed in the pipeline/Se quedo en el tintero.
12284 V 2200 Cherifla TV.........................SNR 62% AGC 99% BER 0.. 10'0dB
12341 V 2120 ORTM................................SNR 71% AGC 96% BER 0.. 11'5dB
12344 V 2120 TM2 (ORTM2)....................SNR 68% AGC 96% BER 2.. 11'0dB
12458 V 23330 DVB-S (??).......................SNR 46% AGC 99% BER39.. 7'5dB
12482 V 15000 DVB-S2 tp data.................SNR 22% AGC 96% BER11.. 3'5dB
Archived-1
Persona non grata
uk
Hi, I am only getting Cherifla TV, ive not scanned here for a while, are the other transponders active please.
Tururu
Yes.
Continue tp's assets.
If the deco is smart to do a search for these 2 tp's, only the last is sought (12341 and 12344) to have the same labels / identifiers.
Si.
Continuan activos los tp's.
Si el deco es inteligente, al hacer una busqueda de estos 2 tp's, solo queda el ultimo buscado (12341 y 12344) al tener las mismas etiquetas/identificadores.
12284 V 2200 Cherifla TV ........................ SNR 59% AGC 96% BER 0 .... 9'5dB
12341 V 2120 ORTM ................................. SNR 59% AGC 99% BER11 ... 9'5dB
12344 V 2120 TM2 (ORTM2) ................... SNR 62% AGC 96% BER 6 .. 10'0dB
12482 V 15000 datos tp DVB-S2 ............... SNR 22% AGC 96% BER11 .... 3'5dB
Anonymous_1
Yes.
Si.
Data from Hylas 1 at 33.5°W not on 31.5°W.
