Measuring angles
No skew just backwards and forwards in the holder, I would have to check the transponders but I got a signal on a 60E TP with the lnb fully forward, I then kept trying for one at 17E and was unable to get any movement I moved the lnd fully backward and got a sniff of a signal,
That is happening because LNB's phase center location is frequency sensitive; higher frequency- more backward LNB should be moved.
I rest my case now Rimants, I am glad you have come to your senses and agree :-applause there is no ideal place for an LNB so now stop messing about with these laser pens and G spots and bits of string :p:D:).
Did somebody mention the G Spot? I've been looking for forty years.
But it has to be fully in to get a signal from 62E and fully out to get 17E, so no ideal place :), what you should make is something that moves the lnb backwards/forwards :).
Certainly, for usual user LNB's centered position will be enough in all cases. For Fringe geeks like you , Martin movement of LNB along it's axis can help, and already helped. o_O Do not forget, you only moved LNB along axis, not even changing skew, no left/right and no up/down movement. Of course, all this do not apply to those who never start any projects and only can do is critics :-lol
You have a masterful grasp of the obvious Einstein :), I agree with the second bit :-lol
Bit off topic
Have plenty of projects, but as i`m not endowed with your superior knowledge of dishes and le point g, fix my fringe reception by trial and error, with loads of patience.
Think my projects though small show results.
Regards
@skomedal Why do you think I was speaking about you?! I've said we have no such persons here! Do not take it personally.
Or it is "A guilty mind betrays itself"?
In, out! . . . . . In, out! . . . . . You shake it all about! :-buttkick
Offtop
Generally speaking, not pointing to anybody, doing practice without any clue about theory, sometimes makes no sense. Does not matter how much labor of Sisyphus applied, final result sometimes pitiable, regardless of patience and time spent.
