Getting Started On C Band
Archive-8
I am getting confused.Not hard I may add.
According to what I have read.With my TM5402HD.
For right use V.
For left use H.
My TM scanned this transponder in as 4116 V
Flysat lists the transponder as 4115 L
That means that my TM5402HD should have scanned it in as 4115 H.
Please enlighten me.:)
Turn the plate in the lnb.
pontiend
Contibruter
south yorkshire
Thank you Chris.I am new to C Band.I have a lot to learn.
I do not have the plate in the LNB.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
For right use V.
For left use H.
Did the same thing and think is was CJ that guided me and I guess it is threads like this one that will be a great help to other C-Band beginners.
Enjoy your weekend. :)
jase1
Vu Duo2,1.2 CM,1224 H to H 57E-30W. Sky dish.
Cheshire
The C band LNB turned up today. I need to mod the dish now to take it.
I get a clear view to around 57e before the dish hits the limit/wall. and 30w the other way. Which side should i put the LNB?
I'm using a quad tuner, VU duo 2. I've got two feeds off the sky dish and 2 off the motorised. I plan to swap the CM feedhorn for a single IBU and use the second feed for the C band. How do I set this up?
jase1
Cheshire
Bump....anyone? Do I need a diseqc switch? Is there another thread covering this?
Thanks in advance
Jase
