7 East 10721 H.
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
I always use BBC Persian on this tp when going to 7 East. No signals on the transponder evening of 4 March, pretty sure it was there yesterday. I can't see anything on the usual transponder update sources.
Yes gone here on 10721 H + 10761 H no signals now tried a Blind Scan no new symbol rate in use.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
10721 H is ok down here. It's peaking 100%. No sign of 10761 H though.
This is why we can no longer receive this transponder in the UK with a 100cm dish as it has moved to Eutelsat 7B Europe B footprint that has a tighter footprint over central Europe than Eutelsat 7A has,
This is the future of Satellite TV tighter beams :eek:
http://www.eutelsat.com/en/satellites/the-fleet/EUTELSAT-7B-downlink-coverage.html "Europe-B"
http://www.eutelsat.com/en/satellites/the-fleet/EUTELSAT-7A-downlink-coverage.html "Europe-B"
BlindFaith
TBS 5925
10721H still ok (9,5dB )but 10762H (8PK) is gone.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
EBS Pro scan earlier this morning did not lock 10762 H but a CrazyScan at 16.10hrs locked it albeit with a lower .db and a FEC of 2/3.
1.2m dish used.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Checked again just now as regards 10761 H 2/3 30000 8PSK and Carrier is certainly there, but as LP said FEC should be 2/3. No video though and also when Scan
is done it says no services found. Uploading two Images....Ignore second picture background image of BBC, that's because it remains there whenever it's not re-freshed.
Bugger. Zip on 10721H here on an 85cm Penta :(
BlindFaith
TBS 5925
10762H locked with sufficient margin but the mux only contains garbage
OK here with 10721H, reasonable signal at 4.2dB. Still trying for 10762H.
Gibby 1.2, Inverto BU.
In my area, at 7.0E,the signal is strong on both polarities on the sub-band transponders
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
No, only 2 TPs are working on 7B europe B beam
Raha TV tp
11387 H tp
Tururu
Assembled with recycled parts
Recycled as the owner.
Also blind according to the tuner 10762H30000 DVB-S2 8PSK.
Tambien ciego segun el sintonizador en 10762H30000 DVB-S2 8PSK.
But in the spectrum analyzer has good sign 73'3dBµV.
Pero en el analizador de espectro, tiene buena señal 73'3dBµV.
In this position, the information of the reference site (lyngsat / flysat) is not correct, indicate that it is in the footprint Europe B (EUTELSAT 7B.), calculating to Madrid, we would have a 38dBW antenna are 150cm and 94cm antenna, channels smoothly and others to the limit.
En esta posicion, la informacion de las web de referencia (lyngsat/flysat) no es correcta, indican que estan en la huella Europa B (EUTELSAT 7B.) , calculando para Madrid, tendriamos unos 38dBW que son 150cm de antena y con una antena de 94cm, unos canales sin problemas y otros al limite.
With very good sign(con señal muy buena...10721V27500, LualuaTV
This other tp if footprint Europe B (EUTELSAT 7B.)/este otro tp si esta en la huella Europa B (EUTELSAT 7B.).
Very low level, the limit/muy baja de nivel, al limite...11387H27500 3/4, TVP (TVPersia).
PS: Good fishing.
shawl_who
New Delhi, India
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Will need a devorce to get one though.:)
Just make sure you install a dual LNB ......one for the receiver and one for the wife.
¿What is it with the dishes...why do they not like bigger/more dishes around?
Whatever, seriously I know you love this hobby.
Have a great weekend there. :D
Makes me laugh you can have a couple of big sheds erected in your garden but as soon as you put up a 120 to 180 cm dish :eek:
So on to plan B :)
I will have a big shed erected next to my small shed & then erect a 120cm dish behind it :-bighappy
