Retired moderator
- Vu+ Duo 4K SE
Dr.HD F15
- Maidenhead, UK & Helsinki, Finland
Well, for a single LNB it's not normally an issue as it's only going to one receiver.Just had another thought, how would You earth an offset LNB, for example a BU single?
Cut the outer plastic casing and screw an earth wire to inner components?
The Invacom QDF-031 quad has an earthing point on the LNB case but most do not.
My parents have got an earth bond bar with f-connectors on it so that the outer shield of the coax is connected to earth on all the feeds for a dish shared with the neighbour (semi detected) that was put in when the dish was installed years ago.
However, as I'm not a qualified electrification so I have no idea if this would have helped in your situation. I understand it's there to protect the other receivers or users if one receiver develops a fault or phase differences causes high voltages.
