20.0ºE Arabsat 5C....scan result.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
20.0ºE Arabsat 5C....scan result today 18.00hrs.......1.8m PF.
20.0E 3711 R 2600 and 4054 L 27500
20.0E_3711_R_2600_(2015-01-28 20.04.20)_dump.ts_000009640.jpg 20.0E_4054_L_27500_(2015-01-28 20.53.49)_dump.ts_000007719.jpg
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
20.0ºE Arabsat 5C....scan result today 21.15hrs.......1.8m PF.
Good result for me here!
Nice result :)
20E is the only C-band bird Ive had any luck with at all. (However with a grossly undersized dish in use I wasnt even expecting the limited results I did get) :D
You got the bug then.....
Archive-8
[SATTYPE]
1=0200
2= Arabsat-5C
3=3
4=0
5=5150
6=0
[DVB]
0=8
1=3711,V,2599,34,1,|-47 dBm, 6.8 dB
2=3721,V,6658,34,1,|-47 dBm, 4.7 dB
3=3884,H,12905,34,132,|-44 dBm, 6.3 dB
4=3884,V,27490,56,1,|-40 dBm, 8 dB
5=3934,H,27490,78,1,|-44 dBm, 7 dB
6=3937,V,7729,34,148,|-44 dBm, 4.6 dB
7=4054,H,27490,34,1,|-42 dBm, 7.7 dB
8=4176,V,13920,14,133,|-46 dBm, 4.4 dB
Archive-8
[SATTYPE]
1=0200
2=Arabsat-5C
3=3
4=0
5=5150
6=0
[DVB]
0=16
1=3530,H,4999,56,132,|-54 dBm, 2.4 dB
2=3884,H,12905,23,134,|-47 dBm, 0.6 dB
3=3884,V,27495,56,1,|-44 dBm, -10 dB
4=3936,V,9831,34,132,|-46 dBm, 2.7 dB
5=3964,V,29990,34,134,|-47 dBm, 3.9 dB
6=4007,V,666,34,4,|-49 dBm, 3.5 dB
7=4013,V,3391,34,132,|-49 dBm, 4.3 dB
8=4023,H,15000,34,132,|-46 dBm, 4.6 dB
9=4054,H,27490,34,1,|-45 dBm, 6.5 dB
10=4088,V,14300,34,132,|-48 dBm, 0.6 dB
11=4112,H,1279,45,4,|-46 dBm, 6.6 dB
12=4124,V,5351,?,4,|-48 dBm, 3.7 dB
13=4151,H,3257,?,4,|-46 dBm, 4.6 dB
14=4165,H,1749,23,132,|-46 dBm, 3.2 dB
15=4176,V,13920,89,132,|-48 dBm, 2.4 dB
16=4186,H,3499,34,4,|-47 dBm, 2.7 dB
Laser
What size dish did you use Analoguesat?
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
Scan 20E
Some easy txp.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
¿Anybody able to see 3798 L 1850 3/4?.....thanks.
Scan today:-
Archive-8
[SATTYPE]
1=0200
2= Arabsat-5C
3=3
4=5150
5=0
6=0
[DVB]
0=25
1=3530,H,4999,45,132,|-55 dBm, 5.9 dB
2=3711,V,2599,23,1,|-50 dBm, -10 dB
3=3721,V,6658,34,1,|-50 dBm, -10 dB
4=3740,V,1999,45,5,|-49 dBm, 0.1 dB
5=3765,H,2759,34,132,|-49 dBm, -10 dB
6=3880,H,7288,34,148,|-46 dBm, 8.9 dB
7=3884,V,27490,56,1,|-43 dBm, 7.3 dB
8=3910,V,5998,89,134,|-45 dBm, 1.7 dB
9=3934,H,27490,78,1,|-46 dBm, 7.5 dB
10=3936,V,9830,56,148,|-46 dBm, 5.1 dB
11=3964,V,29990,34,134,|-45 dBm, 6.1 dB
12=4013,V,3391,23,132,|-49 dBm, 5.7 dB
13=4023,H,15000,23,132,|-46 dBm, 5 dB
14=4054,H,27490,34,1,|-45 dBm, 8.1 dB
15=4088,V,14300,34,132,|-48 dBm, 2.1 dB
16=4110,V,2999,23,134,|-47 dBm, 2.7 dB
17=4112,H,1279,45,4,|-46 dBm, 8.1 dB
18=4124,V,5351,?,4,|-48 dBm, 4.6 dB
19=4129,H,822,?,4,|-46 dBm, 4.1 dB
20=4151,H,3257,?,4,|-46 dBm, 6.1 dB
21=4165,H,1749,12,149,|-46 dBm, 4.1 dB
22=4168,H,2022,34,4,|-46 dBm, 1.3 dB
23=4175,H,999,12,21,|-46 dBm, 3.6 dB
24=4176,V,13920,56,132,|-48 dBm, 3.3 dB
25=4186,H,3499,34,4,|-47 dBm, 4 dB
No sign of 3798 my end.
A 1m Orbital. The lnb was grossly maladjusted and I got about 3 tp's on 20E.
I must have another go this summer - last summer was a bit of a write off with the dishes as the missus had an operation on her ankle so I spent the summer running her around & digging her allotment whilst she sat in a wheelchair with her foot raised & supervised :D
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
....... as the missus had an operation on her ankle so I spent the summer running her around & digging her allotment whilst she sat in a wheelchair with her foot raised & supervised :D
Bet u luved every minute...........got your priorities right though.....good man. :D:D
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Yes Receiving it with my 1.5Dish although signal rather weak than the rest. Also Hispan TV and Press TV on 3914R - 8000 - 3/4.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Thanks for that zorbua and the pics....will try again.......just noticed that I did manage to secure it on 31-01-2015 but not since.....my faulty settings no doubt...again. :oops: :D
After a few years break trying (mostly unsuccessfully) on C-Band on small dishes, and nothing better to do today, I stuck my DMX240 C-Band LNB on my Triax TD88 dish fixed on 19.2E, to check 20E. No fine tuning.
The usual strong TPs on 3884R and 4054L.
Up the ladder maybe tomorrow to fix it on the Gibby 1.25 to see what we can get on other birds.
Archive-8
View attachment 76904 View attachment 76906
That's good going with a td88 @Llew
For me the most challenging sat is 5.0w as time of day can play a big part, and the weather. :-)
I don't expect anything too exotic Chris. Might try SES-6 40.5W, I don't think that position was beaming in here a few years ago.
Archive-8
Will you be fitting the lnb at prime position? Or like me in a rail?
I'll be using the Gibby bracket, like this - when I can find it in my spares box.
