Can't get Astra 2E 2F or 2G? Heres where to find the main psb channels
paul gouves
Crete
1.5 mtr IRTE prime focus, Invacom quad, DM800, Sky+HD
Gouves,Crete
ITV3 HD was lost in Crete today.
bema
Kungsbacka
www.sm6muy.se
TV server: Linux Ubuntu 14.04 LTS
TvHeadend 4.1-1355
TBS6904 (Quad DVB-S/S2)
Dish: TD110, Inverto black ultra quattro
TBS6205 (Quad DVB-T/T2)
Ant: UHF 100 El Triax, dir N
Client: Kodi v14.2 etc
Sweden
It's on 11068V according to Lyngsat...
Master list on post #1 edited for the ITV 3HD change
Astra 2A has been switched off today, with the channels moving to the 2E / 2F pan european beams. I'll update the post #1 main chart with the new satellites once we figure out whats gone where.
This is the reason for which today found an increase of the signal on all transponders between 11700-12500 MHz!I hope to keep permanently at the time when Astra 2G will be operational.
Retired Mod
www.timo.me.uk
ITV 2HD & ITV 4HD will soon be moving to 11053H on the UK spotbeam
Its worth noting that Sky are also slowly increasing the FEC on their widebeam transponders. This gives more bandwidth per tp although it also makes them more difficult to receive in cases where reception of the widebeams is ultra marginal.
Pride Of Cucamonga
Valencia (city)
And with a lower FEC - this is the only transponder I can't receive. (Sky EPG still using PE transponder for both channels)
Retired Mod
www.timo.me.uk
I think they switched today so the Sky box could update at any moment.
List in post #1 updated for the ITV 2 /4 HD changes.
Things are getting a bit thin on the ground for distant expats.
M60
Northern England
I expect an email from my relatives in Lanzarote this weekend when, particularly my aunt, can't watch the Coronation St omnibus. The only way up until today for expats to catch up on some ITV shows - repeated on ITV2(HD).
Pride Of Cucamonga
Valencia (city)
A manual scan shows ITV2 and 4 have already left 11758. If I do a manual scan on 11053, ITV 2 and 4 appear, I add them, select from Other channels and get 'No satellite signal'. Yet both work on SKy EPG. What's going on?
Retired Mod
www.timo.me.uk
There are still two channels called ECAM and 4039 on the old 11758H transponder that might still be showing ITV2 HD and ITV4 HD? I can't check as I don't have an HD sub.
Pride Of Cucamonga
Valencia (city)
ECAM says call broadcaster to upgrade. 4039 just blank and says searching for listings.
The signal strength of ITV 2 / 4 from epg is consistent with higher FEC UK transponders, so wonder if coming from a different ITV (UK) transponder?
joddle
Massanassa, Valencia, Spain
Not noticed any difference in the ITVs or Ch4 so far on my little Manhatten box just south of theValencia city.
Pride Of Cucamonga
Valencia (city)
Was only talking about ITV 2 HD and ITV 4 HD, which are encrypted. I don't have a strong enough signal when manually tuning the lower FEC 11053, but can watch ITV2 HD / ITV 4HD via epg channel numbers.
M60
Northern England
Surely if the Sky EPG is now mapped to 11.053H then you wouldn't get them on the EPG, unless some people's STB's are still being pointed to the old TP?
Pride Of Cucamonga
Valencia (city)
Yeah, it's odd. They aren't broadcasting from the old transponder anymore so wonder if EPG pointing to a different transponder.
Retired Mod
www.timo.me.uk
I can see no other versions of ITV2 HD and ITV4 HD. Are you manually tuning to the right settings?
11.053GHz/H
SR 23.0
FEC 3/4
DVB-S2
8PSK
