Technomate 7100HD
Add these satellites next:-
16E Eutelsat 16A
13E Hot Bird 13B/13C/13D
10E Eutelsat 10A
9E Eutelsat 9A
7E Eutelsat 7A/7B
5.0E Astra 4A
Use this chart to find the active transponders http://www.flysat.com/satlist.php
nicolas46
Nottinghamshire
Southwell - Notts
Ok all done!!
So 28.2 east BBC News Signal Quality 83%
30.0 west God TV Signal Quality 78%
0.8 west BBC World Signal Quality 73%
nicolas46
Nottinghamshire
Southwell - Notts
16E Eutelsat 16A
10E Eutelsat 10A
9E Eutelsat 9A
7E Eutelsat 7A/7B
5.0E Astra 4A
OK about Admin moving this thread!!!
I have to finish it there for today, but will be back tomorrow (Sat), hope that's ok with you!!??
Use these strongest transponders to add these TV channels
16E Eutelsat 16A 11303 H 30000 Al Jazeera Balkans
13E Hot Bird 11136 H 27500 Bloomberg European
9E Eutelsat 9A 12053 H 27500 Real Madrid TV
7E Eutelsat 7A/7B 10761 V 30000 TRT Sports ect
5.0E Astra 4A 12283 V 27500 Inter+
To add a single transponder select the satellite then go to:
Menu/Advanced Search now scroll down the transponder list to select & then scan if the transponder is not there then add it manually by pressing the green button & add the data.
Now go through the data base of each satellite that you have scanned in & delete the dead transponders,
1st move the dish to an active satellite that you have added a transponder,
Menu/Installations/Advanced Search now move the cursor over the transponders if the signal bars do not move then delete the transponder via the yellow button,
Make sure you are on the satellite by moving the cursor to the active transponders then proceed to clean out the data base.
Do this on each satellite position you have added today we will then move onto the Blind Scan.
Blind Scan each of the satellites you have added just use the Free to Air selection or go for All & scan the whole Ku band 10700 to 12750 on 28 east, 19 east & 13east,
Then delete the channels that do not clear,
On 16 east select 10700 to 11700 & 12500 to 12750
On 9 east select 11700 to 12500
On 7 east 10700 to 11700 & 12500 to 12750
On 5 east 11700 to 12750 .
Retired Mod
www.timo.me.uk
Admin note: Moved this thread over to the Technomate HD section.
Ok all done!!
Not bad can be improve on later on by tweaking the Lnb & dish.
No problem you seem to be making good progress now.
