TurkmenAlem/MonacoSat 520E (52.0°Ε)
tempo
47.5N, 42.2E / Russia
First test carriers appeared 20 minutes ago: 10722V and 12459V (the first and the last transponders?)
Both carriers used in wide-band mode, maybe modulated
Test carrier 10723 V and 12456 V
11304 H, 11421 V and 12418 V
tempo
11303H, 11421V, 12418V
adonis1
All in orbit tests will have been completed on 31 of May 2015.
Into the next ten days of June, the satellite will be delivered by constructor "Thales Alenia Space" to Turkmenistan authorities.
tempo
Test carriers 10803V, 11380V, 12226V, 10843V, 11421V received yesterday
tempo
Test carriers 12284H, 12456V, 11303H, 11380H, 12418V
tempo
A lot of test carriers received today:
12226V, 12264V, 12245H, 12399H, 12284H, 12437H, 12360H
tempo
12303V, 10880V, 11400V, 11220H, 12380V, 10723H, 12456V, 10803H, 10760H
tempo
10840H, 10925H, 11340H, 11420H, 11250H
tempo
Again a lot of test carriers were on May 21:
11345V, 12284H, 12322H, 12264V, 12303V, 12341V, 12380V, 12418V 12456V, 12226V, 12245H, 12360H, 12399H, 12437H, 12476H, 10760H, 10720H, 10803H, 10845H, 10880H and others.
Sometimes I had received upto 7 test carriers simultaneously.
tempo
Additional spectrums
tempo
tempo
More spectrums
tempo
More spectrums
I created a provisional frequency plan, the combination of data that I own with the frequencies tested...
  • MonacoSat_1.pdf
I actually used a ruler at the LCD display to determine tempo's carrier frequencies!
In low band, 36 MHz transponders separation seems 41.5 MHz, for 33 MHz transponders seems 38 MHz.
10719.5 - 10761 - 10802.5 - 10844 - 10885.5 - 10927
11219.5 - 11261 - 11302.5 - 11342 - 11380 - 11418
This grid better fits tempo's findings. May be offset a bit of course, depending on his LNB offset.
11343 V very good signal on my 88cm :)
tempo
This grid seems to be close to real. For example, I have measured active at the moment TPs :
11220H+V, 10929H, 10845H, 10761H
Offset of my LNB is about +2 MHz to the most of frequencies posted by another people.
