46E (Azerspace 1)
Weird things happening now on 11135 V 28800 and 11175 V 28800.
Weaker than usual, but 11135 V locks and scanned Harmonic package, TRT HD and TRT BELGESEL HD.
Turkish package started on 11054 H 30000 5/6 DVB-S QPSK.
11135 V and 11175 V still "in construction".
Are you receiving 11175V? I've pretty much lost it as I get about 1dB on it - nothing more.
11135V is completely gone here. Can't see 11054H either. Central Asia beam?
Edit: purely out of interest, I phoned Sky C and they told me that everything should be back tomorrow. Apparently, they are having "technical issues"....hmmm....
11054 H 30000 5/6 gone here now
Current line up here:-
10998V 3570 5/6 S1
Kultura
KDRTRK
Test 3
11024 V 12698 5/6 S1
Alternativ tv
Region tv
Gunesh
TTV
11094 H 27500 5/6 S1
1tv georgia
Rustavi 2
2 tv georgia
GDS
Maestro
Imedi tv
Adjara tv
tv 11
1v 3
Obieqtivi
Marneuli
Saperavi
Palitra
11134 H 27500 5/6 S1
Lider tv
Rossiya
THT
HTB
CTC
OPT
Anstv
S Haber
Space tv
Euro AZ
RU tv
Dunya tv
AMC
Exactly the same line-up here.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Can't see 11054 H either here.
Jamie A
I checked late last night.
11054 H 30000 5/6 was active with about 10 SD Turkish channels. No signal now.
11135 V was active, albeit slightly weaker, with the two TRT channels hvdh mentioned. No signal now.
11175 V was hovering at around 4.3db, and still is now. Not enough signal for a lock.
I also note that a new continuous ACM signal has started at 11066 V 2370 3/4 in DVB-S2.
Kveys
Southern Finland
Here up north 46E now ->
10998V (13.7 d:cool:
(11002V 2222) (8.8 d:cool: This is maybe feed?
11014H (5.8 d:cool: weak and not watchable
11024V (10.4 d:cool:
11094H (7.2 d:cool:
11134H 1(10.6 d:cool:
All of these were stronger earlier. BUT cannot say any real fact because here was quite storm few days ago and it might made little harm for my dish, maybe?
Armenian channels now also on 60E. 11622V 8527 (BISS) strong signal 17.5 dB. Flysat says that another Armenian/Gerorgian what ever freq 11675V 30000 using same spot 1. Maybe it use, maybe not but this freq only about 3 dB here and even that strenght I think thanks to FEC (1/2). No chance to lock now.
Edit: I didnt put these :cool: signs. I meant deebee:-doh:-rofl2
Just spoke to someone "on the inside" and they said that the technical issues are down to some to a single person screwing something up during maintenance. Duh...
aceb
Prof Tuner 7301 /
Sussex
Just checked this on the 1.2 and both 11135V and 11175V are decent enough signals.
Edited to add that 11002 was indeed a feed, BISS encrypted and IDing as Service 2, it dropped out while I was blindscanning. 11005V 2222 is still active, 'TANDBERG' a political rally in Turkey.
Yeah, looks like they are all back now. Some channels on Sky Caucasus are FTA at the moment. Reception seems flaky.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Can receive all except 11054 H although need just 1 - 2 db to be able to.
Kinohit NTV-PlyuS is fta on 11134 V 28800 showing a gangster film atm
Pretty shocking quality though...
Jamie A
A new mux has appeared.
11054 H 28500 3/4 DVB-S2/8PSK
Network: Harmonic
PMT PID 32 (0x0020) - Program 1 ISB CH1
PMT PID 53 (0x0035) - Program 2 ISB CH2
PMT PID 64 (0x0040) - Program 3 ISB CH3
PMT PID 75 (0x004b) - Program 4 ISB CH4
All channels are encrypted.
CA System ID: 9728 (0x2600) EBU (BISS-E)
CA PID 38 (0x0026)
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
Network: Harmonic
CA PID 38 (0x0026)
4 x feed baku 2015 european games
http://www.baku2015.com/
Sky Caucasus package back on European Beam
11174 V 28800 S2 HD MPEG-4
These are fta
Vip TV HD 1920 x 1088
Dro TV HD 1920 x 1088
Saperavi TV HD 1280 x 720
100cm dish + TM5502HD 82% Quality
--------------+ TM6902HD 72% Quality
MBrincat
1.2m motorized dish, VBOXII positioner, Titanium LNB 0.2dbs,
Dreambox 800HD
Malta
These are my signals on 1.2m dish from Malta:
Satellite: AzerSpace-1 (46⁰ East)
10988 H 2400 5/6 (DVB-S) European Beam… (Irmak TV) 6.5db (40%)
10998 V 3570 5/6 (DVB-S) European Beam… (Kultura; KDRTRK) 17db (100%)
11014 H 30000 5/6 (DVB-S) Central Asia… (Euro D, Yaban TV…) 7.5db (46%)
11025 V 12690 5/6 (DVB-S) European Beam… (Gunes TV, Türkel TV…) 13db (81%)
11039 V 3700 5/6 (DVB-S) Central Asia… (UTR, Kahkeshan TV) 14db (88%)
11054 H 28500 3/4 (DVB-S2 – 8PSK) European Beam… (ISB Channels) 11.5db (70%)
11095 H 27500 5/6 (DVB-S) European Beam… (1TV Georgia, Palitra TV…) 11.5db (70%)
11135 H 27500 5/6 (DVB-S) European Beam… (CTC, AMC…) 14db (89%)
11135 V 28800 5/6 (DVB-S2 – QPSK) European Beam… (KinoHit) 11.5db (71%)
11174 V 28800 5/6 (DVB-S2 – 8PSK) European Beam… (SkyCaucasus package) 12.5db (78%)
11175 H 27500 5/6 (DVB-S) Central Asia… (Idman TV, Ictimai TV…) 10db (63%)
Laser
Would respectfully suggest 10988H 2400 Irmak TV is on Central Asia Beam..?
