That will be Absolute Radio I guess! D12 will be off air by later this morning, the new replacement on TP 104 should be live by tomorrow morning so not long to wait.
11.686V 22.0 5/6what frequecy tp 104 on astra use it ?
686? not 679?
I can't see anything here.the signal up now ?
New measurements......As a comparison, the remaining multiplexes on the E28A super beam have these levels...
11389 H - 9.1db 74%
11390 V - 11.4db 74%
11426 V - 10.9db 74%
11428 H - 9.2db 69%
Then there are these levels from two multiplexes on the E28A spot beam 1...
11662 H - 9.7db 69%
11681 V - 12.7db 69%
Astra 2D arrived at 5.2°E, beacon signal near 10701 V, and also near 10942 H it seems.Centre of box table now shows Astra 2D is on its way to 5.2°E.
Will be there around 10 July.
My children were trying to watch Raiders of the Lost Ark on ITV or something like that the other day and every so often the picture would break up. Skies were clear. I went out to fiddle with the LNB, and lo and behold - I find my T-90 is out of alignment. I had a proper crack at it yesterday evening and now am back to nearly 11dB (according to the solo2) on the UK spot TPs. It was closer to 6dB prefiddle - the dish must have moved during numerous high winds over the past couple of years. I'm not completely happy with the realignment - I did it by skewing the dish and now the centre LNB on 19.2E has slightly worse performance (15dB as opposed to 16+) but I can live with that for the time being - 19.2E is very strong over FranceI'm noticing much lower signal on BBC and ITV (T-90). I only checked the signal levels because I was trying to watch the Champions League final on ITV HD and it was breaking up with clear skies![]()
