43.1°W (Intelsat 11)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
As UK Cbanders will know ..this sat is for the most part practically impossible for us without a dish bigger than 3 mtrs.
but 12 months after I finally got a sniff of Intelsat 11 ..Cholusat returns..
Its weak and lock is not consistant..but do-able on Christina..
There are 2 new low SR channels listed by Costa ...but sadly they are Horizontal ...and again this is a no-no for us in the UK..
at least thats what I find..
Vertical is the only way in ..and that's very limited..
Perhaps if you live further South in the UK ..you might have some success..
Anyway around 12 noon Cholusat is lockable..
here are a few pics
rgds
VS
aceb
Prof Tuner 7301 /
Sussex
Funnily enough I'm still parked on 40.5W from last night, I'll wade up the garden and remove the plate!
You are almost on the edge of the footprint up there. You're right; further down south it should be doable on a smaller dish.
aceb
Prof Tuner 7301 /
Sussex
That's as strong as I've ever seen it (7.7dB SNR) and I notice it now scans in as Canal 36. Also worth mentioning that this used to peak around mid morning and would be well on the way to fading out by this time of the afternoon so will try and rescan it at the weekend. However, I have lost the Dutch radio stations on 4000. I'll leave it BSing and see if anything else locks.
Costactc
Canada
Just recently did a scan on Intelsat 11 for an arc thread that I'm posting elsewhere. Considering almost 200 channels scan in there aren't too many open:
[background=rgb(250, 250, 250)]Curta- 3841 H 3599[/background]
[background=rgb(250, 250, 250)]Azteca Trece HD- 3827 H 6249 1080i s2/8psk Dts[/background]
[background=rgb(250, 250, 250)]Globecast Feed- 4164 H 3254[/background]
[background=rgb(250, 250, 250)]Tv Eby- 4065 V 2221[/background]
[background=rgb(250, 250, 250)]Arandu Rape[/background]
[background=rgb(250, 250, 250)]Unicanal Virtual- 4060 V 4443 576i s2/8psk[/background]
[background=rgb(250, 250, 250)]Rural- 4029 V 24570 576i[/background]
[background=rgb(250, 250, 250)]Canal 36- 3877 V 1545[/background]
[background=rgb(250, 250, 250)]Tvsa Int Latino- 3854 V 5944[/background]
[background=rgb(250, 250, 250)]Tveo- 3835 V 7779 576i s2/8psk[/background]
[background=rgb(250, 250, 250)]Teletica- 3828 V 3300[/background]
nelson_b
Contributor
hi -
probably the wrong time of day - and being 50 miles north of greater manchester i don,t expect to get anything from here ,
but one has to try - l.o.l.
i can report a slight trace of signal 0.0 --- 1.5 on the f-15.
regards - nelson.b.
pride21
Sandown Isle of Wight
hi all tried Canal 36 last night its the strongest i ever had at 51-52% quality,tried this morning its at 47% quality and solid picture.cheers
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
I finally received Intelsat 11 @ 43W.
Have only received 2 x Vertical & 1 Horizontal.
Did not think it would be possible to receive in southern Sweden, in view of the problems you have in England with it.
Both lower elevation and much further north.
Appendix 1 is Vertical
Appendix 2 is Horizontal
Lasseparabol
3 m Prodelin
Echostar AD-3000IP
Dr.HD F15
Sweden south part
I finally get the Intelsat 11 @ 43W.
Have only received 2 x V txp & 1 st H txp.
If no attachments work in my last post, so here are the values
3828V 6.0dB
4003V 5.0dB
3967H 5.4dB
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
3843 H 3600 3/4 locked today with 1.80m
Try again ..
having messed up the post ..
2 scans H and V showing all I can currently receive at this location ..
I guess I'm too far north & west.
No TV currently strong enough just one data transponder in the Vertical scan.
Been a long time since I locked anything from 43W
rgds
VS
Anonymous_1
Here are my scans, not amazing but not so bad for a LNB "shifted" about 6° (not sre if it's the correct english word).
PS; feed on 4166 H 7200 locked but enc
New lock
3872 V and 3875 V
Costactc
Canada
I just performed a blind scan for free channels on Intelsat 11 and noticed many more open then ever before. 39 channels in the clear and and tp 3827 H 7500 has the strongest signal at 12 db on my Technomate 5402 M3 with my 3m mesh. The average db level is about 10 with several between 7 and 9 db.
Costactc
Canada
I also noticed that Syfy and Universal West are itc:
3808 V 15000
H.264
11 db
SyFy Latam (SF90) @163054_29JUN2015.000.ts_snapshot_00.03_[2015.06.29_16.31.58].jpg Universal West (UN7 @163021_29JUN2015.000.ts_snapshot_00.02_[2015.06.29_16.32.19].jpg
Archived-1
Persona non grata
uk
Hi Evan, by request ive edited your title, I do hope you don't mind, you do state you have chased this bird for 12 months in your first post, I do know how important it is to mention the chase because I always do :).
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
No Probs Martin ..
It was very relevant at the time because it was aimed primarily at UK fringe Cbanders..but of course we have a much more international membership now than was the case when the post was first made.
rgds
Evan
Archived-1
Persona non grata
uk
No Probs Martin ..
rgds
Evan
Thanks Evan, yes great catch, yes we have a good bunch with some interesting finds :), its now on my list for the future to chase :) .
Anonymous_1
4156 H 3332 3/4
Arpeggio and a testcard (Futbol id)
and lock Woohoo of 3838 H
The screenshot of the logo:
all with a 1.80m dish
edit: unknown channel logo on 3854 V 6250
