Astra 2E: Scandinavia & Baltics Reports
^^^Thanks, as written earlier I tried, but can't figure anything out from the charts, on my testing receiver (which got a good linear measuring, %'s continue below picture lock) 2F uk goes from around 85% midday to 10% evenings. Dish alignment etc does nothing, signal just goes away, I could as well have been located in Moscow for some evening hours. Anyway, no problem, only channel I'd use from 2F is BBC 4 hd.
2E uk has an evening drop as well but just slight, stays well within lock apart from just a few days so far this year (weather?).
This is my theory. In Finland I see different variations depending on which satellites I'm looking at and also at different locations in Finland.
Satellite A reception cuts out at some point during the daily cycle whereas Satellite B keeps a decent lock.
Spot on explanation timo:)
If you hover the mouse on solid dots as provided in charts you can see the variation/wobbles that affect fringe.
Regards
2e uk in good shape here. Apart for a few evening 'beyond reception' scares it's been very stable.
Currently am particularly happy for having ITV4, the Isle of Man TT programs. Great :O)
Some of FTA channels has moved to Astra 2E Uk beam ;( That is causing problems here in Norway Drammen area. I get channels on 11390 v 2/3 27500 on evening. SNR is 4.8db -27 % guess that to low. BBC and ITV SD channels are 6db. I have Triax 110cm with maxium 0.2 db quad lnb. it many years old . Will it help with inverto LNB or Opticum Premium Quad LNB 0,1db ? Or do i need bigger dish ?
Dont want to buy big dish :(
Whilst a new lnb may help there is absolutely no substitute for more metal collecting the transmitted signal.
And to get decent rain fade allowance you may need to go up 2 or 3 dish sizes.
I will first try new LNB but will wait maybe channels are moved back to European beam. These are Asian News channels noting to do on UK beam :)
Btw how big dish u use to get 36e ? Do u get all channels ?
Dont hold your breath for the Indian channels to move onto Europe beams. Which channels are you parrticularly interested in - they may be available elsewhere.
A battered old 80cm dish for 36E - I get a handful of channels (Im currently getting 7 or 8)
Not available else where. I am looking for ARY News and Dunya News which has moved to 2E UK Beam.
Sorry i mixed 36e with 38e. I am interested in 38e
...is something around 10 meters considered big? ;O) see http://flysat.com/paksat1r-beam.php
Someone on the forum may tell if it's possible at all in Norway.
About 28.2, do try some different lnb's and adjust the setup, signal may improve by a few %'s which may be enough to keep a lock on some channels. Don't expect miracles. My experimentations with 28.2, with some luck and finetuning am gaining a few %'s of improvement\quality chosing some lnb over another, but very small fish compared to what a large dish does.
Very bad reception of 2G UK-beam right now. The verticals are very very low (they are usually the strongest). 11053 H breaking up.
Might be caused by the activation of 11082 H and 11112 H on the European beam? Maybe I ought to try some skew adjustment.
I have friends with 120cm but they have less signales than my :) And all quality 120-125 dish are expensive to. Will try with new LNB hope that helps else must get new dish and better place to install
open view to the sat ...and almost as important: easy to reach for adjustments! Good luck.
If you need to, try the inverto black ultra or the opticum.
They also work very well with a larger dish, so no money wasted... 8-)
Thanks will try :)
Just ordered Inverto Quad Black Ultra IDLB-QUDL40 0,2 dB from HM-SAT lets hope that will help :) B
Got Inverto Quad Black Ultra delivered today from hm-sat . Getting 2-3db more than my old LNB . Have 97% signal's on some channels.
Will do some more tests in coming weeks :)
