C band feeds
55.5°W 3759 V 7200 3/4 now , good signal
PS: enc @ 47.5°W by EBU
Feedsat_DXer,
If you get the opportunity on Saturday AM early would you please be able to scan 68.5E for a C Band feed on 3781 H, SR 7119.
It should be the Sri Lanka vs Pakistan cricket match if they keep the same signal details as Friday.
Thx
Feedsat_DXer,
Thx
Yes OK, but not sure, it's too early (or too late 2:45 CET...) for my local time
Until now cricket feeds were FTA on 4164 H on the usual BT testcard,if someone else can pay attention tonight...
for BT Sport 1 (old match screenshot)
Feedsat_DXer,
The cricket feed I asked about on 3781 H, SR 7119 is not the usual BT Sport feed, it is a feed of the Sri Lanka vs Pakistan test match and not a BT Sport feed.
However, many thanks for the info about the BT Sport feed, it is very useful to know.
Rgds
Feedsat_DXer,
Rgds
Ok, sorry for the mistake, I am not a cricket specialist....
@moonbase , yes 3782 H is active but in BISS
@kingkad : Yes, here is a screenshot of a new channel on test on this TXP
there is another feed on 3768 H 7500 3/4
4064 H BT tower feed show a testcard and 4175 H is off
Feedsat_DXer,
Many thanks for testing for the 68.5E feed on 3781 H, SR 7119.
What signal level are you getting on your 3.1m dish for this feed?
Rgds
Feedsat_DXer,
Rgds
About 8dB, not strong when all the frequencies are active on the transponder (37668 H is also "on") but enough for a lock
58.0°W Intelsat 21 - 4165 H 7198 3/4 DVB-S2/HD 8PSK
55.5°W Intelsat 805 - 3739 V 3331 3/4 DVB-S2 8PSK
here: testcard
Feedsat_DXer,
Thank you for confirming the signal level.
Would you please be able to let me know what C Band LNB and feedhorn you are using on your 3.1m channel master dish that you used when getting 8db?
Rgds
Feedsat_DXer,
Rgds
I use the Titanium C1WPLL and the Titanium Flat scalar included with the LNB.
The Pope Feed 55.5°W 3712 V 3333 3/4
The arrival
now, last clean popevaccumm.webp up of the Pope car...
For sports fan
3963 H 7120: Boxe (Calfin Vs ?) it start right now
3990 H 7200 Rugby: Patagonia Vs ?
4042 H 7120 3/4 Judo (Great Britain ;) at the moment )
