Terryl
- Apr 14, 2011
- Age
- 82
Custom built PC
- Deep in the Boonies in the central Sierra Nevada mountains of California.
I tried various bottles, but wanted something bigger as I may change the Ku LNB back to C Band, so need the extra space to accomodate the conical scalar.
Try a plastic coffee can, snip the thing down one side and cut the bottom off, trim to fit, a worm gear clamp will hold it on. (large 4 to 5 inch clamp for a dryer exhaust hose)
And "C" band should not need one, it is mostly weather resistant if your dish is big enough.
