Retired moderator
- Vu+ Duo 4K SE
Dr.HD F15
- Maidenhead, UK & Helsinki, Finland
I also used to be with Virgin (and NTL before that) but my problem with Virgin now is their upload is quite slow unless you go for their top expensive package (30-50Mb download would be more than enough for me) and they still traffic shape uploads if you upload a lot. As I want to use my connection for VPN and a couple of Slingboxes, it's not good for me especially as they restrict it right during peak evening TV viewing times. If I didn't need the upload I'd be back with Virgin as I've been waiting two years for BT to switch on my cabinet.I left them for the very same reason around 2010, Since then they have changed the policy no caps between 16:00 and 22:00 there so called peak time. They now only reduce the upload speed and the download is Unrestricted as long as you take an Over 30mb connection
Code:http://my.virginmedia.com/traffic-management/traffic-management-policy-30Mb-or-higher.html
