Advice Needed Problems with new motorised set-up
  • Thread starter Thread starter Archive4
  • Start date Start date
Don´t start a sentence with And !
Says who? Fowler's Modern English Usage (Oxford Unisersity Press) says it is perfectly acceptable practice. And it is a construction that has been in use since Anglo-Saxon times, and no self appointed grammar policeman or 1960's diktat is going to change that. :-rofl2
Guess it's just where I was dragged up. Went to the Winchester County High School for Girls ( Westgate Comprehensive ) when I went. Turned down the scholarship to Winchester, didn't like the way they spoke!
:-lol
While I await the arrival of the new Dark Motor, would like some thoughts regarding a more wind resistant dish. The Triax 60cm seems pretty good, but I would like to go to a 1.1m / 1.2m dish to pick up more. Anyone have experience of a good dish in a windy environment?
My Laminas has showed no signs of damage due to gales over the last five years or so. Fairly sheltered position though.
channel master/andrew/skyware global or laminas,visiosat/cahors,triax dap(only 60/70/90). all these are SMC dishes. gibertini do high spec aluminium dishes also. a 76mm pole and polar mount/jack combo.
With the 110 it's not so much a case of damage, more vibration. The 110 moves so much in the wind it suffers a lot of signal loss. Watching the Paul L golf earlier, one second 9.4db the next nothing due to wind
Looks like a Triax TD88...
I´m hope it is. I look after a black one in Quesada, while I was there the other day to do a re-alignment I realised how good it is. It´s 35mm pole mounted to get above the roof and although smaller than the Fam lh110 gets better reception on the weak signals. Very good dish
There was a 1.8 with a polar mount on ebay last week Brian, the dish was located in Spain unsure of the exact location, it was on for £20 and never got a bid and was relisted, unsure if its still there maybe worth having a look at that price ?
Re - aligning a TD88?.....you must have grown a third arm....
It looks to be the same as my Triax. So called 1 meter but measures 97x 86.
RE reply 69 forgot to put the quote in.:)
It says Triax under the green paint.:)
Thanks for the info Martin, but I better give that one a miss for now, need to finish the smaller motor unit first.
On that note, I have put the " Triax " on the motor will go from 45W to 65E and back again. Signals obviously better than the 60cm I had on there, but not quite as good as the LH110, no chance of seeing UK spots with the BU single on it, may try a GI twin as I usually gain about 0.5dB with the twin.
Will probably wait for dark motor to arrive before I do much more, should be here this week.
Have just received a sms and e-mail from SEUR to advise the package arrives tomorrow. They gave me the option to delay for one or two days for no extra charge. Good service!
