Advice Needed help telneting to my dm 500s
sut
sky plus box
birmingham
hi guys.
could do with some help if you dont mind please.
i have just done a factory reset on my dm 500 and started the process of resetting the box up. the issue i have is when i have attempted to connect to the box via telebt on dcc it keeps failing, i never had this issue prior to the restore,
i have tried several different passwords from root, admin, dreambox, vuplus, but nothing seems to work, i am currently on windows 10 but have also attempted to connect via my lappy using windows 7 but again no luck,
i have shut down firewalls on both systems and still no connection.
is anyone able to give me some advice in relation to this please.
thank you
anthony
hi guys.
thank you
anthony
When I had a Dreambox it was 0000 or password.
Yes password is dreambox and root
do it again and try
i have tried both 0000 and dreambox with the same result,
Is it one with a dodgy card share on it? You may need to flash a new image onto it to override the vendor settings..
Could be that Analoguesat - I use my 500 as a server and changed password to make it safe(er)
Some dream boxes have the user name as root and password as dreambox, but some of the images have a blank password.
Worth a try. Are you using a backup image? As they can have different passwords set, you would have to go and read where you got the image from.
i attemted to leave the passwod blank but still no luck. the imahe i have on the box is the same 1 i have had on it for years and never had this issue before.
could it be a router issue as the router was reset a day or 2 prior to resetting the dreambox????
Did you check your receivers IP Address?
Have you tried another program, possibly a FTP program, like Filezilla, to see if that connects to your receiver?
i assume the ip address is ok as DDC ftp connects to the box only the telent side fails to connect, i have tried using putty and again that will not work
You could try the VU+ Control Centre. I find it easier than the Dreambox Control Centre.
Do you actually get as far as the password prompt? Is telnet definitely active? You could try SSH.
