36E (Eutelsat 36B)
36E is an odd one. According to footprint maps, there's no way we should be receiving Sub-Saharan beam but I can get at least 1 transponder on my 1.2m Fibo with others also being visible. And the Russian beam - well, that's a first in the UK. We are clearly sat between the two beams here.
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
hi nelson
impressive as well you are receiving the Russian beam as i see your 2nd pic shows NTV+ as the package !!!
well done !!
nelson_b
Contributor
12072 V transponder is now well below lock at 2.5 - 3.0 db
12092 H still locking ok
I really do have to go to work now -- i would love to play further today !
RimaNTSS
Some SAT-related hardware.
N-E from Riga
"hats off"! What can I say- congratulations! But I still do not understand how that is possible!
I guess there's a hot spot of sorts up north? Doubt I'll get anything down here but I'll try...
Archived-1
Persona non grata
uk
Martin/Nelson, could you post a screenshot of the channel list on 12092?
Under lock atm Alex and ive deleted my earlier scans, 0nly getting a sniff 20/25% conditions overcast, as soon as things change I will post up, i am also getting a lock at 12174 V 4340 TNV 11727 V 27500
So those frequencies are from 36A Russian beam - very surprising, especially as 36B has a longer reach into Europe than 36A.
adonis1
12092R at 8.0 db, with linear lnb, the strongest tp of Russian beam.
with circular Ku band lnb, I have reception of all tp of Russian beam of Eutelsat 36B, and no one of also Russian beam of Eutelsat 36A.
nelson_b
Contributor
I spent quite some time, a couple of years back trying for the Russian beams and never even had a flicker of signal before. and had given up looking. i can only think something has changed to enable it to be received here now.
Thanks Martin for trying - and spotting this t.p. signal this morning :)
still locking it here at around 4.5 db
Well done lads - most impressive results :)
nelson_b
Contributor
Cloud cover has finished it for me too ----- no lock now on 12092
Archived-1
Persona non grata
uk
What are your conditions nelson please, ive done no final tweaks yet but last time I looked i was only getting it @2.0/2.5 db, I tested the 0.1 lnb this afternoon and the 0.2 is lots better, my conditions now,
Edit just seen your post about cloud.
nelson_b
Contributor
I have full cloud cover now (no blue sky) the cloud with you looks a little more dense though
lock is back again with me at 4.5 db
when i lost it db level just jumps around between 2.0 and 3.0 db
I certainly cant remember any other reports of the Russian beam here in the UK.
There was someone in London trying it on a 3.5m dish a good number of years ago (before 36B was up there) and they did get signal but it was very variable and generally unwatchable.
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
Though I do recognize that its a good achievement, but all of you are so surprised as if the beam is so very far away.
Its reaching pretty close to UK.
Generally, signals travel better over sea/water, as it doesnt face any hindrances in its path.
People in South India, have caught beams over africa, in India, with big dishes.
Archived-1
Persona non grata
uk
Thanks nelson
Well its the same here Alex not a constant lock, but from whats been said and some reading ive done the signal should improve with the correct lnb ?.
Does anyone know where to locate the below LNB in the uk please ?
(The Inverto IDLB-SINR41-H1060-OPP should do instead, covers 11.7...12.75 GHz with our standard 10.6 GHz LO:
http://www.inverto.tv/products/product.php?section=1&id=47&cat=29
Archived-1
Persona non grata
uk
@nelson_b have you tried bard again with the change of lnb ? maybe worth a look now pal.
Its coming from 36000 miles almost straight up. Sea path isnt going to make much difference for satellite signals (unlike say tv or radio transmitter signals).
Unexpected reception is that unusual I agree, Ive had unlikely reception myself in the past but this really is unusual. (However its also fair to say very few folk here in the UK have very large dishes due to lack of room & strict planning rules)
Kveys
Southern Finland
