Archive-8
I found the silver line one to be the most accurate, but that was about 1/2° out. And I have already sent of for A digital protractor.
The black inclometer I had was 3.5° out :-( so I used my silver line one, that's only .5° out, and I will wait for my digital thing from China :-)If I would have only sent for one, and got the one that's a fair bit out, I would struggle to get a signal after 10 E, that's how far its out![]()
.........but back to my old method, the STB.
My favorite method also ( if you have the patience ) true and tested with the stb concerned for fringe reception, my gibby 125 is pole mounted @ 150cm height so take the stb ( techno 5402 mk2, wish I had the mk1 ) connected to a 12" crt tv ( also used a 19"lcd tv ) and fine tune to best reception from astra 2E psb tps, funny thing is not a wiff of tps from astra 2F psb channels.
Saving up for a larger dish but have other priorities ATM
Regards
BTW all non psb tps boom in with 96%Q from the astra birds but no use too me
These have always worked fine for me.Well I have sent for this one now.
http://www.ebay.co.uk/itm/DXL360S-D...Box-0-01-UK-/221356485992?hash=item3389dfed68
Unfortunately I can not get anything on 36 east at the moment, the tree that's in the way is slowly dying.Your in Sheffield with a 1.8 how are you getting the Russian beam at 36E and 17E could you post your results up ?,
I have a Wikey and its good. Maybe cheaper elsewhere.
_____http://www.machine-dro.co.uk/wixey-digital-angle-gauge-with-magnetic-base.html
