new:
11974 v 3/4 29500 dvbs-2/Qpsk
copie of the 11597 v
Yes, helpful...No problem receiving them here. Maybe you need a bigger aerial.![]()
The BT sport channels swapped transponders with a lot of Asian channels (now on 11.597V). My guess is it wasn't that BT Sport wanted to be more restricted, it was the Asian channels that wanted to get on a wider European beam just as they where before on Eutelsat 28A and as BT Sport is only for the UK they didn't worry about switching to a spot beam.Well, if that's the case why leave the SD channels on a wide beam? All they're doing is guaranteeing a flood of cancellations and the vast majority of those people then adding Sky Sports. Me included!![]()
Inspiration channel recently joined the BT Sport SD channels on a 2G Europe transponder moving off a 2F UK spot soon after the Eutelsat 28A moves so I suspect that BT transponder is staying put for now.I wouldnt be surprised if they move eventually.
My understanding is it was a temp move and one that was changed alot sooner than planned because some signal issues with those who don't have their dish set up correctly were losing pictures.
Its also why certain stuff was being live-simulcast on BTSportESPN while they were on the temp txp.
Not to me. A transponder is either strong enough for purpose or it is not. If it is not it wouldn't be used even as a temporary measure.Makes sense as 2G Europe is a fair bit weaker in parts of the UK than the other beams.
2G Europe is weaker than 2E/2F Europe and a lot weaker than 2F/2E/2G UK spot over almost all of the UK though. I can see the difference just outside London and others have reported even worse reception further north. To be honest I'm quite surprised at how just much use 2G Europe is getting. Levels are more like the old 2A/2B than the new generation of satellites.Not to me. A transponder is either strong enough for purpose or it is not. If it is not it wouldn't be used even as a temporary measure.
IMO, most likely reason for the switch is so that at some time in the future error correction can be reduced to increase bandwidth.
