16/32 APSK capable satellite receivers (was: Dr HD D15 16/32 APSK)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Did you see box finding that transponder in blind scan? I can see the fox news transponder found at 45E, but it can't find the channel. I remember also seeing 16APSK data tranponders found in blind scan listed in flysat.
No ...
Sadly I wasn't paying attention during the blindscan of 24.5W ...but next time I will ..
but ..even if there was no lock ..
I would have thought manually entering the parameters into the SX6 whilst a 14db 16PSK channel was present would at least have shown that 'something' was present even if it couldn't be locked ?
That's why I'd like someone with an SX6 to try the same ..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So I took a look at the Fox News feed at 45E..
First with the TBS card just to see if I could get it and at what strength ..
The answer was yes ..and around 8db ..
Should be enough to register on the SX6 ..though not neccessarily lock it ...as it is a continuous stream ..
but Not even a hint that a signal was present ...
Its as though this box is blind to 16 and 32psk ..
Surely there should at least be a sig level reading even if not quality or lock..
Getting frustrated now ..and feeling like I've wasted my money..
The only Vertical transponder found duting a full blinscan was 12558V (Prima)
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
I've had issues with receivers before where if in Motorized mode , when scanning they will move the dish slightly , try it in Fixed mode .. even a loop from the TBS if it has one
huve
Faval SH 100, Mystique SaTiX-S2 Sky V2 USB, GI 110 cm, Inverto Black Ultra single
Helsinki
You can not lock at 8 dB. For 3/4 32APSK theoretical error free picture is 13 or 15 dB SNR (multi or single carrier).
Does the BER work, it's zero in crazyscan. Or is it so low that it can't figure out BER. Crazyscan probably uses some kind of estimation method to get the 8 dB SNR.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The dish cannot move mate ..
once I had it in position on 45E I cut the power to avoid this possibility..
In truth huve I wasn't really expecting a solid lock at all ...just some indication that a signal was present on the SX6 ...but it appears deaf to it ..
As to the TBS card tried it again and is still locked showing no BER all zeros ...so says the tuner otherwise it would say No-locked...but no data possible(currently claiming lock at 16PSK)
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ok ...so I went back to the first post in the thread ...the video showing reception of the 12718H multiplex ...
Which again the TBS card can lock and can resolve ....
but the SX6 doesn't even register ANYTHING in a blind scan ..
Are we sure this isn't a con job to sell more of the Ffffing boxes ?
Or again ..
perhaps a firmware upgrade is needed ?
The video clearly shows it working but damned if I can repeat this trick ...
Mighty frustrated atm
VodzigorLans
Setup is down atm
RU, Saint Petersburg
This is a first thing to do before scan anything. Multistream and 16apsk features were added in latest firmware versions only, not by default.
I found this site a while back for the Openbox SX6 it may help you
Google Translate
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks for that Vod ..
much as I suspected ...
could you please point me at the latest firmware which does allow these features ?
or perhaps upload it to this thread if you have it ??
cheers
VS
VodzigorLans
Setup is down atm
Can you connect it to internet? It can download latest firmware from web with flashcard inserted.
Latest firmware with СI+ and HbbTV support:
yadi.sk/d/kiMQpUsagwLzR
without those features:
yadi.sk/d/b7Hpy4ISgwLmh
links from openboxfan.com
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cheers ..
Haven't got it connected to my Lan as yet ..it being a new addition ..but will do this as soon as I can ..
Unless someone uploads it here first ..
cheers
VS
Archived-1
Persona non grata
uk
I would no its not blind, satcards see things a stb will never see, find another tp that's 8db with the sat card and test again one that not 16/32psk and there's a good chance you will get the same result on that box and any other you want to try.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
This is dragging on a good bit ...
Do I assume that the multistream fix is not an official firmware upgrade ?
I have connected the SX6 to my lan ...and inserted a blank usb drive ...then selected software download ...
A list of firmwares were grabbed from the net and displayed ..
selected the most recent and went through the motions ..
the box completed the upgrade but still does not find the multistream transponder either by blindscan or manually ..
So ..now I'm wondering if somehow I have to point at another URL to get this ?
If so ...how ??
any help would be most welcome ..as I'm close to pitching this box through an open window..
rgds
VS
Archived-1
Persona non grata
uk
Some more multi streams here to look at, unsure what's still active but its the most up to date list I can find
http://www.technomate-community-forum.com/forum/index.php?threads/which-satellite-has-multi-stream-tps-please-help.1219/
VodzigorLans
Setup is down atm
Ok, lets go with 12.5W since there are two multistreams work with SX6, do you get other channels from that sat? like 12595H1875 5/6? Are you sure your dish is in correct position while scanning?
Archived-1
Persona non grata
uk
I wonder how Phantom is getting on with his efforts to develop a box, last I read he was working on it, maybe @william-1 might have some information for us ? :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
After much searching on the net I can find sod all on this subject other than demos of multistream working ..
I've got the latest software in it v3.02.06 and it point blank refuses to even acknowledge the existance of the 14db multistream signal on 12.5W ...
So thats it I guess ...
it will make a wonderfull paperweight ...or pehaps handy to prop open doors...
a £130 joke ...and really not that funny ..
It looks for all the world like they have changed something about the build ..and have either used a different tuner that doesn't support multistream or 16psk ...
or quite simply ..it's faulty..
I have no idea what to try next ...and am well p1ssed off with it already.
I guess the jokes on me..
Archived-1
Persona non grata
uk
Now that's a thought, is the actuator still miss counting Evan ? you might be off the spot?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Yes ...
and Yes
I have already posted a scan of the multistream signal as seen by the TBS card ..
The signal is over 13 db and more than adequate ..but the SX6 cant see anything ??
The SX6 is currently showing KTO at 97%
Archived-1
Persona non grata
uk
Well if you can clear them at 12.w ?, the tuner/the signal is to weak for a lock problem solved ?
