Eutelsat 8WB (8W / 8.1W) C-Band Active
empb+
Motorized Triax TD110 (1.06m) x2. TM 0.1db Ku-Band & 13K C-Band. WeTek Play (Ku & C-Band), Technomate TM7102 (Ku & C-Band), Openbox S2 Mini (Ku-Band). Basic PC but with Fausto EMU & vplug server installed.
Blackpool (NW, England)
C-Band Active:
3929 R (V)
again with:
Al Jazeera Channel
Al Jazeera Mubasher
Al Jazeera English
Al Jazeera Documentary
Qatar TV
Al Jazeera America
Al Jazeera Mubasher
C-Band Global Beam:
In the middle of Blind Scan @ 61% as I type (will confirm SR after scan but this tp when repeated usually 27500 as it is on 20E C-Band 4054 L DVB-S/MPEG-2 27500 3/4 and 8.1W Ku-Band 10971 V 27500)
empb+
3929 R (V) Yes SR 27500
8W C-Band 3929 R (V) 27500 & Ku-Band 10971 V 27500 duplicates
Nice catches! Is that on your TD110? Must be pretty a pretty strong C band signal.
empb+
On TD110
edit: further erroneous info from defective scan removed
mar-val
Slovakia,Zilina
You are scanning C band with Ku lnb.
5150-3929=1221
1221 + 9750 = 10971
Nothing here on 220cm dish.
empb+
:( Not changed Tuner from 2 to 1 you are right - grrrr
The Bird has fired up Ku-Band on the MENA footprint and should have strong C-Band looking at projected footprint, so just need to keep checking (On the correct F.. ing tuner thou).
edit: Too Much Coffee, Not enough sleep! :(:mad::eek::-doh:-doh:-doh
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ...
Do I take it there is nothing yet active in Cband at 8W ?
I've created a space for it on the F15 and a Vbox posn ...
but possibly jumped the gun in light of the above ?
rgds
VS
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
So ...
but possibly jumped the gun in ligfht of the above ?
rgds
VS
Checked it a couple of a hours ago, nothing came in.
empb+
Don't you just hate when copy / pasters missquote your incorrect info:
edit: I have contacted Flysat to tell them to remove this incorrect info
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
Reception report of Eutelsat 8 West B @ 8° West by Peon.
3808 LHCP - Nina TV
3840 LHCP - Channels 24
8,0wC 3808 L, Nina TV.jpg 8,0wC 3840 L, Channels 24.jpg 2015-11-24_110143.jpg
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
This morning at 12.15hrs.
Can anyone please advise if 3825 L 23705 is still active and as detailed above by 'Feedsat'.........thank you.
3808 L 1250
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Anonymous_1
T2-MI stream 4153 L 60000 3/4 (copy of 3°E)
"Easy TV Package" for Canal + Africa
Promo and Tele Congo FTA
MIS1 PLP1 MIS 2 PLP2 MIS 3 PLP3 & 5
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hi Chris1979,
I can confirm your scan from position 8.0°W.
Best Regards
qwer.
