Fraccaro 1.2 with Ka Band A
Had this dish going spare, so thought I would try it with the Hughes for the ITN stuff, quite impressed so might fix this on 19E, as just a dedicated ITN feed dish.P1010001.JPG P1010002.JPG P1010003.JPG P1010004.JPG P1010005.JPG
Nice job scopus :)
Yes, I have my Triax 110 and SL3 fixed on 19E. Waiting now for the Hughes HN9200 to compare. When they decide to post it...:rolleyes:
Nice job scopus :)
Think you will find quite an improvement Llew, I did compared to the SL3 on this dish.
That dish looks very much like a 1.25m Gibby.
Archived-1
Persona non grata
uk
Nice little setup scopus :), love the axle stand idea ?.
Archive-8
The only difference between the one in the photo and my gibertini 125 is the lnb holder. Other wise it's identical.
@scopus the lnb in the picture, does it pick up H&V ? Or is it single polarity?
Yep, it looks like an axle stand lol. It's a spare two and a half inch pole with some concrete weights on it. Going to put in a more permanent home soon
Just vertical Chris. The H/V job is on the 1.8.
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
its the older version, the new one has a 1 piece boom arm/different lnb clamp and are badged by fracarro amongst others
Archived-1
Persona non grata
uk
Nice little stand that's all that's needed if you there's nothing in the way :). i guess you will just drill the mount bottom and use the bolts on the blocks as a levelling system :).
