Archived-1
Persona non grata
- uk
Hi samoloko, yes I can make them, I will be making one in the near future for my 1.8, at a later date when I have my workshop built I will be making them to order, but there is a Q, if you need one asap satellite super store have them ready made on the shelf.can you make such mount but for Channel Master dish 1.8
I would like to buy one
So that's what you meant "hands off my mount"...I would just like to thank @RimaNTSS for going out of his way and getting me this new mount, it arrived safely this morning and ive just picked it up, thank you Rimants your a good un
Any more reflectors in the shed?
Maybe they should make those out of SMC-material too?Reflectors are quite common, it's the feed arms that are becoming rare (they do rust, eventually).
Hi st1, when i bought the 1224 it came with a CM 1.2, i will be selling the 1224 soon but i want to keep the 1.2 that came with it, now i have a mount to for itSo that's what you meant "hands off my mount"...
But now it's time to spill the beans:
What will you use this for?
You have a CM120 on a Polar Mount
And a CM180 on currently a H2H motor, soon to be another polar mount
And a PF 150cm dish on a DIY polar mount (of an enviable design and quality).
And a sky dish for the missus. (Strangely not on a polar mount)
...so what's the next CM polar mount for???
, i will probably use this at low level for messing with KA band in the future
I have seen only one antenna which feedarms are made out of plastic, but that was only 75cm. I think that for bigger dishes it is not so easy to make plastic feedarms as they would be heavy and could also be affected by weather conditions. Best material for antenna's periphery (mounts, feedarms, LNB holders, supports etc.) is .... you knowMaybe they should make those out of SMC-material too?
But fishing rods are made our of plastic - even the ones you catch sharks with??I have seen only one antenna which feedarms are made out of plastic, but that was only 75cm. I think that for bigger dishes it is not so easy to make plastic feedarms as they would be heavy and could also be affected by weather conditions. Best material for antenna's periphery (mounts, feedarms, LNB holders, supports etc.) is .... you know![]()
Well the CM's are definitely made of steel.I am unsure if the precision arms are aluminium ?, the ones that was on the 1.5 are like new.
carbon
Cheaper and stronger (and a 20 year old dish is outside of warranty...)
I made new arms for my CM180, and tried Aluminum - but it was too bendy.I think carbon might cause signal loss Rimants, i know you cant use it with ham radio antennas
My 1.2 is an old dish but the arms are still like new, if i was to make some i would probably use aluminium.
I am little bit disagree about weight of INOX. It is absolutely not necessary to very thick-walled tubes. Welding of aluminum is another issue.
And price of aircraft aluminum could be high.
, welding Aly is not a problem to me and aircraft quality/grade tube is cheap enough, i made a 11mrt band antenna from it last year for under £30 in tube.
