Newbie Here Advice on card subscription
stephen211270
Technomate TM5402 M3
Maxx Digital Satellite Dish 1.1m
NVERTO BLACK ULTRA HIGH GAIN SINGLE LNB
SUPREME DARK MOTOR LED METAL GEAR DiSEqC 1.2 / 1.3 USALS
Liverpool L4
Hi guys I was thinking of subscribing to Al Jazeera Sports now does anyone know of a cheaper option than Al Jazeera Sports JSC+ NEW IRDETO CARD FULL SPORT 18 Channels ! PREMIER LEAGUE also what cam card would I have to get
Archived-1
Persona non grata
uk
Hi Steve moved your post here pal, you will get a better response.
Those card require a dedicated receiver, which can be bought together with the card. I don't think there are any CAMs for these packages (which is annoying).
TJExcalibur
Out of this world.
Southern England
I'm a little bit cautious regarding cams. If it is to easy to use on to many scrambled providers channels I think they will spend millions on making it more difficult. As it is only those who love to mess about with satellite receivers etc who bother with cams and most do not. As we all know, many sellers have been raided for selling boxes with opt out oif subscribing software.
Well, there are still a number of providers that work officially in CAMs, such as Vivacom Bulgaria - they use Videoguard!
JCS/beIN sport isn't one of them though. The receivers they supply are pretty good, I think, as they are Humax ones underneath.
stephen211270
Liverpool L4
Niceone Martin:) apologies for not posting a new thread in the correct place and thanks for the reply guys
I did find a site that sales beIN Sport 1&2 for £269.94 with cam VIACCESS SECURE CAM ACS 4.1
Archived-1
Persona non grata
uk
Its not a problem Steve no need for an apology, you will get more response here, please listen to peeps carefully and make sure you can lock the transponders in all weathers before you part with your money :).
stephen211270
Liverpool L4
signal and quality over 90% martin
Like Martin said, the ones you scanned are part of French CanalSat packages and are not the ones that carry 3PM footy games. You need to check 7W...
stephen211270
Liverpool L4
stephen211270
Liverpool L4
7.3 is definitely no good when quality goes below 50% picture goes of
I'd say you're doing pretty well on a 1.1m in Liverpool to get that.
They are not easy to get but not impossible. The number of 3PM games there is limited though...
Ghostleader
Glasgow,ish!
We talking Viasat on 4.8E?
Sent from my T5 using Tapatalk
stephen211270
Liverpool L4
stephen211270
Liverpool L4
does that mean if I get a bigger dish say 1.4m my quality bar would go up ?
Ghostleader
Glasgow,ish!
It's on the Nordic beams bud, not an easy catch the further north you go in the UK.
