- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
I am, of course, crazy, but no so much .If you have £2500 lying around, anywhere!
Depends on whether you can find something used.I am, of course, crazy, but no so much .
Looks possible > Hvilken tuner?Still have the HD-decoder 2850-ST box, can I reload new software into it to open other sat. fta channels, have 125 gibby?
.. swedish website blocket second hand. still a speculation of 500 quid - but included polar mount and electrical heat jacket to melt snow in the winter. It may be up for sale soon again if I don't get a success.Hi Marti! Good start, from very first post and 2,4m Channel Master! Welcome here. Looking forvard to see some pictures of your installation.
P.S. Where you guys getting those CM 2,4m dishes?! ;)
Let me know and i'll bring a trailer 'round...but included polar mount and electrical heat jacket to melt snow in the winter. It may be up for sale soon again if I don't get a success.
Ooooh, but that's not really satisfactory is it? Only SD channels...Results are in for Stockholm, Sweden. All 2E UK spot signals being received using the Channel Master / Raven 2.4 dish- although the HD channels are pixellating, all the standard definition channels are perfectly watchable (62% signal on my TM5402 HD, even with a DiSEQC switch). Will see if it drops in the coming hours, but it has remained stable and worked fine from about 230pm when I first got it working. I swapped my Invacom for an Inverto Black Ultra Quad - although I am pretty sure the Invacom should also work now I have got the dish adjustments sorted out (needed a 38mm spanner). Not had time to take a pic yet. Will do some more tweaks to see if I can stabilise the HD channels as well.
A quick guess is that OP is suffering from 28.2 vs 28.5 separation.Cannot understand why the HD channels are pixellating with that barn door size dish @ your location, maybe more tweaking needed
Regards
But of course there are other 2.4s out there
While I don't have access to the UK spot I have the same issues with the Europe beams on 2E and 2F on a 1.2m in northern Finland. It is quite annoying as when Eutelsat 28A left I was rather hoping this issue would have gone away...A quick guess is that OP is suffering from 28.2 vs 28.5 separation.
The bigger the dish, the narrower the beamwidth.
Many HD channels (but not all) are on 2G (28.2E), whereas most popular SD are on 2E (28.5E).
I have this very marked on my 1.8, and it can even be felt on the 1.2s.
On a 2.4, you would feel this quite substantially.
Incidentally, I hate to be picky but Finland is neither in Scandinavia or the Baltics so strictly speaking I shouldn't be posting here....
Yes you can:-
Finland ( i/ˈfɪnlənd/; Finnish: Suomi [suomi] ( listen); Swedish: Finland [ˈfɪnland]), officially the Republic of Finland,[7] is a Nordic country in Northern Europe bordered by Sweden to the west, Norway to the north, and Russia to the east; Estonia lies to the south across the Gulf of Finland. Finland is part of the geographic region of Fennoscandia, which also includes Scandinavia and parts of Russia.
_Finland - Wikipedia, the free encyclopedia
Regards
...and it's part of the Nordics, so in the vein of Stalinistic history-writing, I would simply rename the thread "Nordic and Baltics Reports", and the issue would be a non-issue.
