vu solo 4k
ant user order new vu solo 4k
how the it work low symbol rate ?
Too early to know yet, only pre production models out so far.
I think these are still on advance order so, unless sample units of gone out for review, we may have to wait a while to find out the quality of their performance :)
VU+ have released their own image, for this product, so a Black hole version shouldn't be far behind.
http://code.vuplus.com/
http://vuplus.com/sub/main.php
A fresh review VU+ Solo 4K Review - Linux-TV.com
Next to nothing inside (that's good > less heat). Soon it will be just one chip with some plugs :O)
Can anyone confirm if the FBC tuners support SNR in db? With Vu's driver history it seems more likely the users will stick again with nonsensical percentages!
In Openspa a Spanish forum which is preparing an image for this tuner makes the request.
For that, the million dollar question, which behave as normal LNB.?
Normally VU + nothing works well under SR 2000 (according to the manufacturer's your limit), if any partner has time and can look, then thank you very much.
In Hispasat we have some test channels with low SR (TV and radio), if you have engine, watch channels so you can do testing.
Another question, the BER information is always zero (0) no matter the quality does not vary in this as such.?
Brand like the others, for example.?Quality signal and SNR (dB.).
If you have LNB unicable, as more of the same.
PS: Thank you for the inconvenience and time.
VU+DUO2 Openspa 5.0.1
En el foro español Openspa que esta preparando una imagen para este sintonizador realice la consulta.
Pues eso, la pregunta del millon, que tal se portan con LNB normales.?
Normalmente VU+ no funciona nada bien por debajo de SR 2000 (segun el fabricante es su limite), si algun compañero tiene tiempo y lo puede mirar, pues muchas gracias.
En Hispasat tenemos algunos canales de prueba con SR bajos (TV y Radios), si tienes motor, miro canales para que puedas hacer pruebas.
Otra pregunta mas, la informacion BER siempre esta a cero (0) da igual la calidad, no varia, en este que tal.?
Marca similar a los demas, por ejemplo.? Calidad, Señal y SNR (dB.).
Si tienes LNB unicable, pues mas de lo mismo.
PD: Gracias por las molestias y por tú tiempo.
They have a tuner for testing the image, and will comment if they respond.
Tienen un sintonizador para las pruebas con la imagen, ya comentare si responden.
