Help Required Norsat C-Band on Gibertini 150
Noelsat
Gibertini 150
TBS 6983
Europe
Hello guys !
I've try to grab C-Band with my Gibertini 150 + LNB with Conical scalar ring with poor results.
Yes, i know that 150cm are very few for C-Band but i think with a Norsat LNB i will get better result.
What type of feedhorn i need for mount a Norsat 8000 series on my dish ?
Thank you very much !!
Noelsat
Remember that C-band signals are often fairly weak. Try the 20E sat - some of those frequencies are gettable on a 1m - Ive done it :)
What specifically are you after?
Noelsat
Gibertini 150
TBS 6983
Europe
Thank you for reply.
So i can mount a chaparral polarotor ? Have it a flange for a Norsat + offset dish ? chaparral.net/feed-horns/polarotor
I get some channels on 20E, 3E, 5W, i will get better with a Norsat lnb!?!?
Noelsat
Gibertini 150
TBS 6983
Europe
I found also this type:
tvguy.net.au/index.php?main_page=product_info&cPath=1_16&products_id=199
Is it the right model ? :)
... the link you gave does not bring up a specific product with me, but on that site there is the same thing that i first pointed out and comes with it's own conical scalar. The model number is FC-JSPOS.
Your next problem for you will be how to mount this unit or any of the lnbf type devices onto your present dish. Good luck with it, it is an interesting band to view.
Noelsat
Gibertini 150
TBS 6983
Europe
Work in progres... ;)
.... Good stuff, i also bought one of those simple C-band feeds after mentioning them to you to do some experimenting with ;) Have you managed to get a dielectric plate to use for circular polorised signals ?
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
ses6 40.5w my dish esx241 and av-comm with gibertini150 good reception on Turkey
TV grande rio
gibertini+esx241:%42-43
Gibertini +esx241+avcomm:%53-54
Very interesting results. Looks like AV-Comm is on my list of things to buy.
Do you have a servo motor yet?
