New Inverto KaKu lnb
Checking the E7A LC2 frequency (21584H) on my Promax. TPA carrier to the left on the spectrum.
Going closer into the spectrum, I notice there's a carrier of sorts 1MHz adjacent to 21584H (21583H) that I can't identify.
Could that cause problems if a receiver is trying to lock a weak LC2, bearing in mind that it doesn't seem this LNB is using PLL on Ka - not necessary to have it as it'll be looking for fat carriers when used for its intended purpose, internet / BB via satellite.
I spoke to Dave at SSS today, he is going to order and stock some of the New Inverto LNB's
I spoke to Dave at SSS today, he is going to order and stock some of the New Inverto LNB's[/QUO
.... nice one, what you been ordering then ??
Not ordered anything...honest!!
I have gone down the DXhagens route off the DXTV forum. I have cut off the feedhorn on the Inverto and left enough barrel to copy the Fibo C120 flange so that it fits into the Fibo feedhorn. I had to add a sleeve to get the diameter up to 25mm as the Inverto barrel is 23mm. This has greatly improved Ku, Ka is about the same as with the original Inverto feedhorn, A worthwhile project on my day off.P1010004.JPG P1010005.JPG P1010006.JPG
Archive-8
I have gone down the DXhagens route off the DXTV forum. I have cut off the feedhorn on the Inverto and left enough barrel to copy the Fibo C120 flange so that it fits into the Fibo feedhorn. I had to add a sleeve to get the diameter up to 25mm as the Inverto barrel is 23mm. This has greatly improved Ku, Ka is about the same as with the original Inverto feedhorn, A worthwhile project on my day off.View attachment 87732 View attachment 87733 View attachment 87734
Nice going :D interesting to see some signal figures when you have a chance.
Nice one, good pics as well. Who's next then with a non Fibo mod to try :D
I did wonder about a c120 version of this lnb, so we could try the matched feed horns on our dishes.
Didn't know there was a C120 version Chris, or was you thinking about grafting a CM Ku feed onto it or grafting the Ku horn part of a C120 CM over the original Inverto horn ?? ..... cue VS
@ Scopus Chris, can you not indent slightly the boom arm, or take a bit away ?? so as to slip an F connector up it's dedicated Ka port that's got a tad more performance m'boy ...... do it!.
Archive-8
Its not something I can do, but yes I was wondering about a c120 version, so other feeds could be used.
You can attach an elbow to that connector, so it doesn't foul the boom arm. Will give it a go at the weekend.
I nearly did it that way Chris. I butchered an old White Inverto LNB (faulty) filed it down to fit in the throat on the Inverto Ku/Ka, that would give you the c120 option then. DXhagens did that way over on the DXTV forum.
Archived-1
Persona non grata
uk
Nice work Chris :)
Well the awkward LC2 has gone up in strength since the mod on the Inverto, well pleased!P1010007.JPG
Trust
Nijmegen Netherlands
Nice work Scopus , I did not find the time to do the same .
Are you aware that the other port (Ka only) is more sensitive ?
To use that port I had to change the feedarm , infact a complete re-design of the lnb changer .
I will try the other port at the weekend, John in a earlier post mentioned that. I can attach an elbow f connector to that one so it should clear the boom arm.
Trust
With that elbow conn. you are restricted in skew
bonou2
strong 4500, openbox X801, vantage 7100ts, vantage X201 CI, goldenmedia 9080,goldenmedia uni-box2,tbs6925+,inverto black ultra+C120,panorama er-861, zinwell lnb 15K C- band,intersat 20K
hello to all
where I could buy this lnb KA- und KU Band LNB IDLK-SINL20-KAKUO-OPP?
any shop from england ?
thanks in advance
best regarsd bonou2
